I want to use smoke detectors via smartthings/mqtt broker.
i have it configured and other devices such as switches do work.
Smoke detectors do not work for some reason (do not reflect state), pls help.
You have chosen to use: smartthings/Smoke Detector - Bedrooms/smoke
for the state_topic whereas the SmartThings Bridge is indicating: smartthings/Smoke Detector - Bedrooms/smoke/state
The Smart bridge uses state as state_suffix. I have mqtt water sensors and switches which work just fine so I think that is not the issue but I will try it.
