MQTT Switch Configuration error: Invalid config for [switch.mqtt]: [object_id] is an invalid option for [switch.mqtt]
I have this in my configuration.yml
switch:
  - platform: mqtt
    unique_id: "id_based_on_id2"
    object_id: "id_based_on_object2"
    command_topic: "cmnd/rf_bridge/rfraw"
The “object_id” entry is specified here in the docs: MQTT Switch - Home Assistant
If I set the “object_id” I get this error from home assistant:
Invalid config for [switch.mqtt]: [object_id] is an invalid option for [switch.mqtt]. Check: switch.mqtt->object_id. (See ?, line ?).
Am I doing something wrong?
