All this switch does is turns my Tasmota/Sonoff iFan03 on to its lowest setting, the reason for this is so that I can control the fan from a thermostat entity.
However, I also manually use the remote control to set the fan to its different speeds. ‘{“FanSpeed”:1}’ is the payload for the lowest speed and ‘{“FanSpeed”:3}’ is the highest.
What I’d like is for this switch to show ‘on’ regardless of the speed setting. Is there a way to have the state_on setting do a bit of simple logic like:
if FanSpeed != 0
or
if FanSpeed == 1 OR FanSpeed == 2 OR FanSpeed == 3
If that’s not feasible then any other suggestions would be appreciated.
According to the documentation the payload_on and _off are used for the command topic and if no state topics are defined are also used to compare with the result of the state topic. So in this case is would be better to use
state_on: On
state_off: Off
If you also want to control the fanspeed by HA, you will need an additional control, e.g an Input_Select to send the FanSpeed 1, 2 or 3 commands. Switch on to default speed and switch off by the switch and select speed by the Input_Select.
