I use solar2mqtt integration. I want to create a switch to change my inverter mode between SUB and SBU.
I have two topics:
- powmr/DeviceControl/Set_Command - send command
- powmr/DeviceControl/Set_Command_answer - receive response
The flow is:
- Publish message POP02 in topic
to enable SBU mode. The response will be ACK. - Publish message POP01 in topic
to enable SUB mode. The response will be ACK. - Publish message QPIRI in topic
to receive current configuration frompowmr/DeviceControl/Set_Command_answer
topic. The response will be 230.0 44.3 230.0 50.0 44.3 0200 0200 48.0 48.0 44.8 56.4 54.4 2 002 090 1 2 1 1 01 0 0 54.0 0 1 48.0 10 44.0, where this 2 is responsible for the SBU mode.
How can the switch be configured to send this additional message to receive the current configuration?
At the moment, I have this configuration without the current state:
switch:
- name: PowMR SBU switch
command_topic: "powmr/DeviceControl/Set_Command"
state_topic: "powmr/DeviceControl/Set_Command_answer"
payload_on: "POP02"
payload_off: "POP01"
