I am connecting my Nissan LEAF to Home Assistant through MQTT (OVMS v3). The climate controls work by sending console commands to a “command” topic and responses come from a “respose” topic. The complication is that the response is a multiline response. I got my yaml code from here, and I assume it works for the author, but I can’t get it to work. The YAML seems to match the string in MQTT. Are there any debug tools I can use to see what it is HA is seeing?
Config:
mqtt:
switch:
- name: Leaf Climate Conrol
qos: 1
command_topic: "ovms/mqttuser/STICKY/client/home-assistant/command/1"
state_topic: "ovms/mqttuser/STICKY/client/home-assistant/response/1"
state_on: |
Climate Control
on
state_off: |
Climate Control
off
payload_on: "climatecontrol on"
payload_off: "climatecontrol off"
MQTT transactions:
ovms/mqttuser/STICKY/client/home-assistant/command/1 climatecontrol off
ovms/mqttuser/STICKY/client/home-assistant/response/1 Climate Control
off
ovms/mqttuser/STICKY/event clock.2231
(I included the 'clock` event to show there are two carriage returns after the response)
I expect the switch state to be set to “Off” when the response topic is sent. Instead it always shows state “Unknown.”
What is wrong here?
