[MQTT] Temperature and humidity together
Is it possible to have temperature and humidity been combined together for the same sensor?
Right now I have multiple icons, each for temperature and humidity for each room: livingroom temperature, livingroom humidity, bedroom temperature, bedroom humidity.
I’ve tried this way:
- platform: mqtt
  state_topic: "home/bedroom"
  unit_of_measurement: '°C'
  value_template: "{{ value_json.temperature }}"
- platform: mqtt
  unit_of_measurement: '%'
  value_template: "{{ value_json.humidity }}"
but create 2 sensors: temperature and humidity (without any reference to “bedroom”)
I’ve tried this:
- platform: mqtt
  state_topic: "home/livingroom/temperature"
- platform: mqtt
  state_topic: "home/livingroom/humidity"
Burt in this way it just create a single sensor with the humidity (the last value that comes in).
Thanks!
I think you can create a new sensor with a template sensor that combines the two states of the existing sensors. That way you can keep the temperature and humidity sensors for any automations you may need.
