jeffmn
(Jeff Rutland)
August 5, 2020, 4:54pm
1
Ok, I give. I have dug into this as much as I feel I can, and I just can’t get it to work.
I’m running hassio as a virtual machine on my Synology box. I have many things working quite well, and feel I have an okay handle on things.
I’m trying to set up a Pi machine to monitor temperature and humidity, and send messages via MQTT that I can then monitor in HA. I’ve got MQTT running with other devices and believe I have a good understanding on how this all works.
So, I’ve got MQTT installed as an integration in HA. I can set up a listener in the ‘Configure’ option and see the messages coming through from the Pi. I’ve set up a MQTT sensor in my configuration as follows:
default_config:
- platform: mqtt
name: "Upstairs Temperature"
entity_id: "environment.temperature.upstairs"
state_topic: "homeassistant/test/front-door-pi"
device_class: "temperature"
qos: 0
value_template: "{{ value_json.temperature_f }}"
Can someone tell me what I’m missing here? I’ve run out of ideas, and I’ve restarted HA countless times while messing with the configuration here. I’m not seeing this sensor show up as an entity no matter what I do. Thanks!
francisp
(Francis)
August 5, 2020, 4:59pm
2
Your indentation is way off.
If, what you are showing is your configuration.yaml :
default_config:
- platform: mqtt
qos: 0
And you can’t have an entity-id in a mqtt sensor definition !
jeffmn
(Jeff Rutland)
August 5, 2020, 5:07pm
3
Amazing. That works, and the linter in VS Code alerted me to the entity_id
issue. I moved my configuration out from under default_config: and it is now working.
Maybe this is my issue - I assumed that everything must fall under default_config:
- but I found that http:
for instance shouldn’t be under it. What should / shouldn’t be under this node? Is this something I’ve misunderstood / misinterpreted here? I have many things underneath, such as mqtt
, recorder
etc… and they seem to work fine. Is this not correct? Is there documentation that I’ve likely missed on this one?
I appreciate your quick response. Thanks!!
francisp
(Francis)
August 5, 2020, 5:13pm
4
Most domains need to be aligned totally left.
# Configure a default setup of Home Assistant (frontend, api, etc)
#default_config:
# Individual options represented by default_config
automation manual: !include_dir_merge_list automations
#cloud:
config:
frontend:
history:
input_boolean: !include input_boolean.yaml
input_datetime:
input_number: !include input_number.yaml
input_select:
input_text:
logbook:
#map:
#mobile_app:
person:
script: !include scripts.yaml
#ssdp:
sun:
system_health:
updater:
#zeroconf:
zone:
#includes not in default_config
python_script:
group: !include groups.yaml
sensor: !include sensor.yaml
binary_sensor: !include binary_sensor.yaml
switch: !include switch.yaml
light: !include light.yaml
timer: !include timer.yaml
scene: !include scenes.yaml
notify: !include notify.yaml
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
homeassistant:
customize: !include customize.yaml
latitude: xx.8235615
longitude: xx.1915097
elevation: 16
packages: !include_dir_named packages
# customize_domain:
# light:
# assumed_state: false
mqtt:
broker: 10.0.0.63
port: 1883
discovery: true
discovery_prefix: homeassistant
username: xxx
password: xxx
birth_message:
topic: 'hass/status'
payload: 'online'
will_message:
payload: 'offline'
recorder:
# db_url: mysql://ha:[email protected] /hadb?charset=utf8
db_url: sqlite:////share/hassio_db/home-assistant_v2.db
purge_keep_days: 3
exclude:
domains:
- persistent_notification
- automation
# - weblink
- updater
- input_boolean
- input_select
- input_text
- timer
- weather
- scene
- calendar
- device_tracker
- zone
entities:
- sun.sun # Don't record sun data
- binary_sensor.snapshots_stale
- hangouts.conversations
- binary_sensor.electricity2_button1
- binary_sensor.ikea_button1_update_available
- binary_sensor.ikeaoutlet1_update_available
- binary_sensor.ikeaoutlet2_update_available
- binary_sensor.ikeaoutlet3_update_available
- binary_sensor.ikeaoutlet4_update_available
- binary_sensor.ikeaoutlet5_update_available
- binary_sensor.ikeapir2_update_available
- binary_sensor.ikeapir_update_available
- binary_sensor.ikeapirboven_update_available
- binary_sensor.ikeapirkeuken_update_available
- binary_sensor.updater
- input_select.zigbee2mqtt_log_level
- input_text.zigbee2mqtt_new_name
- input_text.zigbee2mqtt_old_name
- input_text.zigbee2mqtt_remove
- sensor.zigbee2mqtt_version
- sensor.mains_apparent_power
- sensor.mains_frequency
- sensor.mains_power_factor
- sensor.mains_reactive_power
- sensor.upstairs_apparent_power
- sensor.upstairs_frequency
- sensor.upstairs_power_factor
- sensor.upstairs_reactive_power
- sensor.coordinator_version
- binary_sensor.sonoffbasic3_button1
- binary_sensor.electricity1_button1
- binary_sensor.electricity3_button1
- binary_sensor.electricity4_button1
- binary_sensor.electricity5_button1
- binary_sensor.electricity6_button1
- binary_sensor.coolcam1_button1
- binary_sensor.coolcam2_button1
- binary_sensor.coolcam3_button1
- binary_sensor.coolcam4_button1
- binary_sensor.coolcam5_button1
- binary_sensor.coolcam6_button1
- binary_sensor.coolcam7_button1
- binary_sensor.pc_destiny
- sensor.tunex_2f02_update_time
- sensor.tunex_a202_update_time
- sensor.tunex_4503_update_time
- sensor.tunex_b002_update_time
- sensor.tunex_4b01_update_time
- sensor.tunex_4e01_update_time
# - sensor.tunex_3201_update_time
- sensor.alectov1_0048_update_time
- sensor.extern_ip
- sensor.ophaalkalender_papier
- sensor.ophaalkalender_pmd
- sensor.ophaalkalender_restafval
- weather.halluin
- sensor.halluin_freeze_chance
- sensor.halluin_next_rain
- sensor.halluin_rain_chance
- sensor.halluin_snow_chance
- sensor.halluin_temperature
- sensor.halluin_thunder_chance
- sensor.halluin_uv
- sensor.halluin_weather
- sensor.halluin_weather_alert
- sensor.halluin_wind_speed
- sensor.ikeapirkeuken_requested_brightness_percent
- sensor.ikeapirkeuken_requested_brightness_level
- sensor.ikeapir2_requested_brightness_percent
- sensor.ikeapir2_requested_brightness_level
- sensor.ikeapirboven_requested_brightness_percent
- sensor.ikeapirboven_requested_brightness_level
- sensor.ikeapir_requested_brightness_percent
- sensor.ikeapir_requested_brightness_level
- sensor.CC2531_led
- sensor.CC2531_ant_led
- sensor.CC2531router_led
- switch.zigbee2mqtt_main_join
- sensor.xiron_1701_bat
- sensor.xiron_2f02_bat
- sensor.xiron_3201_bat
- sensor.xiron_4503_bat
- sensor.xiron_4b01_bat
- sensor.time_online
logger:
default: error
logs:
# homeassistant.helpers.script: info
homeassistant.components.mqtt: error
homeassistant.components.tuya: error
homeassistant.components.light.rflink: debug
homeassistant.components.sensor.rflink: error
homeassistant.components.rflink.light: debug
rflink: error
rflink.light : debug
device_tracker:
platform: nmap_tracker
hosts:
10.0.0.64
home_interval: 10
google:
client_id:xxx.apps.googleusercontent.com
client_secret: xxx
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 3
rflink:
port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
# host: 10.0.0.190
# port: 7000
wait_for_ack: false
ignore_devices:
# - aster_0ffc_01
# - aster_0ffc_02
# - aster_00b8_02
# - aster_05e8*
# - aster_0bd4*
# - aster_085c*
- aster_*
- ev1527_012af3_02
- ev1527_01285a_02
- ev1527_00252a*
- halemeier*
- blyss_th_*
- doorbell_fe2a_1
- legrandcad*
- renkforcee*
- fineoffset*
- chuango_de8380_02
- selectplus_07ffff_02
- selectplus_00c677_02
- ev1527_022f69*
- eurodomest_2dd096*
- eurodomest_0dd096*
- eurodomest_2ed50c*
- eurodomest_000001*
- alectov*
- keeloq*
- ningbo64_*
- tunex_6202*
- tunex_e402*
- elrodb*
- eurodomest_000900*
hacs:
token: xxx
# python_script: true
appdaemon: true
#rest_command:
# reset_rflink:
# url: 'http://10.0.0.190/reboot'
# method: GET
google_assistant:
project_id: home-assistant-xxx
service_account: !include Home_assistant-xxx.json
report_state: true
exposed_domains:
- light
expose_by_default: true
wake_on_lan:
#camera:
# - platform: mjpeg
# mjpeg_url: http://10.0.0.74:8081
# name: pi_cam
