MQTT topic does not return a value
I appreciate help to solve this problem.
I have this code to read the topics that a raspberry sends me within the same network in the configuration.yaml file
It is not a json string, they are simple topics, with mqtt explorer I can listen to them.
But it does not return any value.
Where is the error?
  - name: "h1voltbattery"
    unique_id: "h1voltbattery"
    state_topic: "PVControl/Hibrido1/H1BatteryVoltage"
    unit_of_measurement: "v"
    value_template: "{{ value }}"
error2-mqttexp
I think you are missing the mqtt: looking at what you posted, so HA doesnt know the sensor is mqtt.
mqtt:
Once you’ve solved it (and I suspect @Dujith is right here; you’ll need to restart after adding the mqtt header), note that
is completely unnecessary and can be removed.
Voltage should be an upper-case "V", and you can use device_class: voltage to get an appropriate icon.
