MQTT Trigger Sensor temporarily gets value "null" when reloading template sensors
I have defined an mqtt platform trigger sensor like this:
  - trigger:
      - platform: mqtt
        topic: house/watermeter
      - name: "Water Meter"
        state: "{{trigger.payload}}"
        unit_of_measurement: "m³"
        state_class: total_increasing
        device_class: water
      - name: "Water Meter Latest Reading"
        state: "{{as_timestamp(now())|timestamp_custom('%Y-%m-%dT%H:%M:%S')}}"
I have a mobile app where I enter a value manually and post it on the mqtt topic, hence the construction.
The sensors above stores the water meter value in one sensor and the timestamp of the reading in the other. Note that the latest reading is just the timestamp of when the topic is read by home assistant. However it works. My latest reading was 3 days ago and the timestamp also reflects that. When I reload my configuration, the timestamp is also preserved like i want. However, there is a short time span during the reloading that the latest-reading-sensor reports "null" and so any automation based on that time sensor triggers.
How can it be that the timestamp sensor report null?
Show those triggers.
Example of automation that triggers:
alias: Laundryroom
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.water_meter_latest_reading
actions:
  - action: input_select.select_option
    metadata: {}
      entity_id: input_select.daniels_location
      option: Laundryroom
mode: single
Trace for automation going from valid state to null:
this:
  entity_id: automation.laundryroom
  state: 'on'
  attributes:
    last_triggered: '2026-05-19T21:20:22.121102+00:00'
    mode: single
    current: 0
    friendly_name: Laundryroom
  last_changed: '2026-05-19T21:25:33.839260+00:00'
  last_reported: '2026-05-19T21:25:33.839260+00:00'
  last_updated: '2026-05-19T21:25:33.839260+00:00'
  context:
    parent_id: null
    user_id: null
  idx: '0'
  alias: null
  platform: state
  entity_id: sensor.water_meter_latest_reading
  from_state:
    state: '2026-05-16T22:42:07'
    attributes:
      friendly_name: Water Meter Latest Reading
    last_changed: '2026-05-19T21:20:22.096329+00:00'
    last_reported: '2026-05-19T21:20:22.096329+00:00'
    last_updated: '2026-05-19T21:20:22.096329+00:00'
    context:
      parent_id: null
      user_id: null
  to_state: null
  for: null
  attribute: null
  description: state of sensor.water_meter_latest_reading
And the trace a tiny bit later showing state going from null to its previous value:
this:
  state: 'on'
  attributes:
    mode: single
    current: 0
  context:
    parent_id: null
    user_id: null
  idx: '0'
  alias: null
  platform: state
  from_state: null
  to_state:
    attributes:
    last_changed: '2026-05-19T21:25:50.172552+00:00'
    last_reported: '2026-05-19T21:25:50.172552+00:00'
    last_updated: '2026-05-19T21:25:50.172552+00:00'
    context:
      parent_id: null
      user_id: null
  for: null
  attribute: null
Try:
triggers:
  - trigger: state
    entity_id:
    not_to:
      - unknown
      - unavailable
