Hi everybody,
i´m struggling to get an automation going:
- a CO2 sensor (via MQTT) ist up and running so that i can see the CO2 level in HA - works fine:
? "sensor 3" : name: CO2 platform: mqtt state_topic: office/sensor2 unit_of_measurement: ppm value_template: "{{ value_json.co2 }}"
- a switch ist installed and running to switch on/off manually the ventilation - works fine:
? "switch 3" : - command_topic: office/switch3/set name: "Ventilation Switch" optimistic: false payload_off: "OFF" payload_on: "ON" platform: mqtt qos: 0 state_topic: "office/switch3/#"
- the numeric value / state should trigger a ventilation switch to start running above 600 ppm level:
automation: - alias: "Ventilation" trigger: - platform: numeric_state entity_id: sensor.co2 above: 600 value_template: "{{ value_json.co2 }}" action: - platform: mqtt topic: office/switch3/set payload_on: "ON"
I´m a newbie and struggling quite a bit to get it going, help very appreciated!
Kind regards!
joe
