I’m trying to dampen a LaCrosse Breeze Pro wind sensor direction by adding a circular average statistic over a 3 minute period for a new package I’m creating for an Awning Warning for my RV. Everything is working without this new sensor. I’m using Degree units DEGREE: Final = “°” the value is numeric but I’m getting this error
Logger: homeassistant.config
Source: config.py:942
First occurred: May 19, 2025 at 10:48:58 AM (1 occurrence)
Last logged: May 19, 2025 at 10:48:58 AM
Invalid config for 'sensor' from integration 'statistics' at packages/breeze_pro.yaml, line 54: The configured characteristic 'circular_mean' is not supported for the configured source sensor '', got {'platform': 'statistics', 'name': 'Wind Dir Avg', 'entity_id': 'sensor.breeze_pro_wind_dir_debounced', 'state_characteristic': 'circular_mean', 'sampling_size': 30, 'max_age': {'minutes': 3}}, please check the docs at https://www.home-assistant.io/integrations/statistics
The package file looks like this:
homeassistant:
customize: {}
mqtt:
- name: Breeze Pro Temp
state_topic: rtl_915rv/LaCrosse-BreezePro/590470
device_class: temperature
unit_of_measurement: "°F"
value_template: '{{ value_json.temperature_F | round(1) }}'
force_update: true
payload_available: online
payload_not_available: offline
unique_id: 41CA5C2ED5344676
- name: Breeze Pro Humidity
unit_of_measurement: '%'
value_template: '{{ value_json.humidity | round(1) }}'
force_update: true
unique_id: C871AF0D2B614F3E
- name: Breeze Pro Wind Speed
device_class: wind_speed
unit_of_measurement: mph
value_template: '{{ value_json.wind_avg_mi_h | round(1) }}'
force_update: true
unique_id: 270ACE67A4E04805
- name: Breeze Pro Wind Dir Debounced
unit_of_measurement: "°"
value_template: '{{ value_json.wind_dir_deg | round(2) }}'
force_update: true
unique_id: 270ACE67A4E04508_DIRFIX
- platform: statistics
name: Wind Speed Avg
entity_id: sensor.breeze_pro_wind_speed
state_characteristic: mean
sampling_size: 30
max_age:
minutes: 3
name: Wind Dir Avg
entity_id: sensor.breeze_pro_wind_dir_debounced
state_characteristic: circular_mean
sampling_size: 30
max_age:
minutes: 3
Am I missing something or is there a problem with Home Assistant core?
