Hi everyone!
I’m working on integrating a MR24HPC1 mmWave sensor with an ESP32C3 Supermini (Tenstar Robot) through ESPHome. While the device connects beautifully to Home Assistant, I’m hitting a wall where all sensor states remain “Unknown”. I’m hoping someone might spot what I’m missing.
Hardware Setup
Components:
- ESP32C3 Supermini (Tenstar Robot)
- MR24HPC1 mmWave Sensor
- ESPHome 2024.12.2
- Latest Home Assistant Core
Connections:
ESP32C3 Pin | MR24HPC1 Pin |
5V | VCC |
GND | GND |
GPIO4 (D2) | RX |
GPIO5 (D3) | TX |
Current Status
What’s Working:
- Device connects to WiFi perfectly (signal strength: -41 dB)
- Shows up in Home Assistant correctly
- ESPHome compilation and installation successful
- All logs look clean and normal
- OTA updates configured and working
The Issue:
- All sensor entities show as “Unknown”
- Includes presence detection, motion sensors, distance measurements
- No sensor data seems to be transmitted at all
- UART communication appears configured but might not be working
Configuration Highlights
Key parts of my YAML:
uart:
baud_rate: 115200
rx_pin: 4
tx_pin: 5
parity: NONE
stop_bits: 1
seeed_mr24hpc1:
# Full sensor configuration available if needed
What I’ve Tried
- Flashed firmware both directly and through ESPHome Builder
- Double-checked all wiring multiple times
- Verified power supply is stable
- Enabled DEBUG logging level
- Checked UART configuration against documentation
- Tried with and without the external components source
Could this be a UART communication issue that I’m not seeing in the logs? Any ideas what else I should check?
Thanks for any help!
