Wow that was already a mouth full ![]()
So I am planning to renovate and want to built a new floor heating system in my house in Japan. Japan is quite far behind when it comes to intergration and uses mainly proprietary systems which wont work locally and don’t usually work with HA. So decided I want to ask my contractor to built a system I can control locally with Shellys. Here the break down:
- Electrical Architecture
• Power: 24V DC Industrial Power Supply.
• Valves: 24V Thermal Actuators (Normally Closed).
• Smart Logic: One Shelly Pro 1 per heating zone and one Shelly Pro 1 for the Boiler heat-call signal.
• Emergency Logic: Industrial Analog Dial Thermostats and Analog Hardware Timer Relays.
- Dual-Path Redundancy (No Single Point of Failure)
The boiler “Heat Call” signal is controlled by two physically separate circuits wired in parallel.
Path A: The Smart Path (Primary)
• Logic: Room Sensor → Smart Coordinator → Shelly Pro 1 (Zone) opens → Smart Coordinator runs a 2-minute software delay → Shelly Pro 1 (Boiler) fires.
• Benefit: Allows for remote access, scheduling, and precise temperature management.
Path B: The Hardware Path (Emergency Backup)
• Logic: 1. Ambient temperature drops below the Analog Dial threshold (e.g., 10°C).
The Analog Dial sends 24V power directly to the valves (bypassing the smart relays).
A hardware Interlock Relay detects power at the valves and triggers a Mechanical Off-Delay Timer.
The hardware timer waits 2 minutes (to ensure valves are open) and then physically closes a contact wired in parallel to the boiler.
• Benefit: This path uses no software, no Wi-Fi, and no silicon-based “smart” logic. If the Shelly units or the network coordinator fail, this path maintains the house temperature.
- Critical Safety & Hydraulic Measures
• Pump Protection: Both the Smart Path (via software) and the Hardware Path (via a dedicated analog timer relay) enforce a 2-minute delay before the boiler fires. This ensures the pump never pushes against a closed manifold.
• Mechanical Bypass: A Differential Pressure Bypass Valve is installed at the manifold as a final fail-safe against high-pressure buildup.
• Staggered Loads: Analog backups are split into “Frost Groups” (e.g., Group A at 10°C, Group B at 8°C) to prevent all zones from snapping open at once, reducing thermal and hydraulic shock to the boiler.
- Wiring Overview:
• Zone Valves: Wired in parallel to both the Shelly Pro 1 (Zone) output and the Analog Dial output.
• Boiler Signal: Wired in parallel to both the Shelly Pro 1 (Boiler) dry contact and the Hardware Timer dry contact.
• Isolation: The boiler’s signal circuit remains isolated from the 24V power circuit via these dry-contact relays.
Before I pass my (theoretical) plan to my contractor was wondering if you guys could have a look and let me know what you think. Was also planning to use temp sensors inside the flooring but the tough part was what’s written above. Also not sure this should be posted here or in hardware, if wrong pls lmk
