Multiple BT ESP32 Proxy but only one gets used?
I have two Bluetooth ESP32 Proxy devices connected via WiFi.
I simply flashed the ESP32 BT Proxy firmware via the web installer.
Additionally I have multiple bluetooth devices from Shelly (window/door sensors as well as motion sensors).
It seems like all those Shelly Bluetooth devices are connect via only one ESP32 device.
This causes some of the Shelly bluetooth devices to have very bad signal since they connect to the furthest ESP32 device instead of the one close to them.
Additionally if I check in Settings → Devices → Bluetooth → Connection Slots Allocation Monitor:
Both bluetooth devices (=ESP32 devices) show 0% used connection slots.
This can’t be correct either?
Thanks!
Is correct. BLE advertisements don’t use a connect slot
Hmm okay thanks. Is there any way to check which bluetooth devices sends data to which ESP32 proxy? Like a network map?
@francisp
No idea. I have 4 BLE proxies in the house, but no idea what device uses which proxy.
