I am new to Home Assistant. Brand new…just got the mini PC today with HA loaded on it. My system is having a hard time finding many devices including:
- Sonos
- Govee
- Eufy
Any assistance would help
Have you tried following the setup instructions?
e.g.
You can search for the others here:
I have it set up exactly as the instructions read. I even tried to port forward by adding a virtual server off my IP doing the following:
Inbound Port 1400 to 1400
Format - Tried TCP and Both
Private IP Address: Entered my IPv4 address
Local port - 1400
First time trying a port fowarding so it took me a bit to find it
Why would that port be blocked on your local network?
Did you expose that open port to the internet in your router?
If so, remove it. That is a security hole you do not want.
Tell us how your local network is set up. How are your Sonos and Home Assistant devices connected?
