Hey Guys,
I’m testing out the Dynalite integration and have notice a few things. I managed to add multiple Dynalite gateways to the integration which took a bit of time to work out.
I also have all three of the host/gateway settings set to Active Mode set to “Always”, this seems to be working on the first host/gateway I added to the integration but the other two don’t seem to be polling their systems for status updates.
If I add a Lovelace card with the lights on it, then use the actual light switches in the room to turn the lights on their states wont update. This is not the case with the first host/gateway, in this one if I change the lights using the switches it does update in the UI.
The other thing I noticed was this seems to be the same for the auto discovery function, it seem to be working on the first host/gateway but the other two don’t discovery anything, even if I disable the auto discovery on all but the one I’m trying to discover.
Appreciate any help you could offer.
Nathan
