Multiple ESP Devices / One ESPHome Device
Hi All,
I need to deploy several dozen ESP devices with the exact same config and they will receive the same commands (On, Off, Dim).
Is there any sort of one-to-many option in ESPHome or will I need to add each individual device and issue commands to each device from Home Assistant?
If not and I have to add them all to ESPHome individually, is there a way in home assistant to issue commands to a group or devices at the same time?
I have many nodes with ESPHome installed.
To clarify; if ESPHome is installed on nodes, then HA will “integrate” them. If set up correctly, HA will recognize them immediately and will set up entities corresponding to the buttons/ switches / lights and other functions that have been set up on your node. At least just one click to accept each recognized node into HA
Yes. Automations can do some clever stuff, sending same command to entities/ devices for as many ESPHome entities as you want. I am not aware of any limits.
