MULTIPLE ESP32s
Can’t find any info on line, but what is the procedure for adding a second or third ESP32 to my Home Assistant. I need the bluetooth coverage throughout my building. thanks in advance
It should be autodiscovered and if not then just add the ESPHome integration again with the new device.
how can I confirm the auto discovery? Where will it show up?
s
Same place as updates to Home Assistant Core.
never got an alert…hmmmm
sure you have the line
api:
in your code?
esphome:
esp32_ble_tracker:
  scan_parameters:
    active: true
bluetooth_proxy:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-A2Fff4"
    password: "MVXZrCGYTf5A"
captive_portal:
Another Question Justone
Do I need to do the esphome upload via USB as well? If so, do I need to rename it?
Not sure I follow the last question, but essentially, you will create a new ESPHome device over USB w/unique name. mDNS is used, unless otherwise configured, to locate the device by the HA Integration.
Once it’s picked up by ESPHome add-on, you’ll be able to perform further configurations and updates over the air.
So, yes, a unique name should be chosen.
PERFECT/FANTASTIC…thanks for the assist guys
You seemed so knowledgable that I want to throw something else at you. My ESPs keep going off line and I cannot get them back on line. I see them on my router and I can ping them with no issue.
thoughts?
