According to my router, my home assistant system seems to be uploading about 3GB of data a day to somewhere. That seems very unexpected to me, and I’m worried there is malware or something like that. Is there a good way for me to track down what is causing this?
Speedtest integration installed ?
Good suggestion as a possible cause, but no, I haven’t installed that one
Are you using one of the backup functions such as backing up to Google Drive?
Google Drive backup add-on maybe?
I do have that installed. I’ll try disabling it for a few days to see if it drops. Thanks for the suggestions everyone!
That will upload your backup to Google Drive every time a backup is scheduled.
So with a daily backup schedule and backups of 3GB that would explain it.
You can check both in the GUI of the add-on
Thanks. I checked the backups and a full backup is 3GB. Problem solved! Thanks all.
If your problem is solved, please mark the corresponding answer as solution, so others can see it right in the title. Makes searches in the future easier! Thanks!
