My Home Assistant is running on a Home Assistant Yellow, with added NVME for storage.
I have 3 different IKEA remotes, and since yesterday only one of them is working.
E1743, an On/Off Switch that I use for my kitchen, this is no longer working, battery has been replaced.
I have tried removing the device, and adding it again. If I use the Developer tools to listen to events while adding the device - I get this output:
And device was added successfully:
But additional clicks, does not show up in the event trace. -
I have a E1810 Remote, configured for my office to turn on/off and also dim the light. Also stopped working. Same as above, re-adding it shows a trace:
Added
But button clicks does not trigger past automation traces, nor event traces.
This still works:
- FHO-E2002 (Styrbar) remote, configured for my office as well.
Events are triggered, here an off and then an on event:
And I can also see traces in my automation:
For testing purposes, I tried removing the E2002 - And it was correctly re-adopted.
Is there a way of resetting the remotes no longer functioning?
