I’ve got some weird behaviour when trying to run multiple instances of an app. It’s probably something simple that I’ve missed, but I can’t figure it out.
It’s takes a name as an argument (‘wakee’) creates some variables to listen to an MQTT topic and control a hue light to turn on before their alarm.
lights_alarm_rise_ben:
module: alarm_rise
class: AlarmRise
wakee: ben
lights_alarm_rise_emma:
module: alarm_rise
class: AlarmRise
wakee: emma
class AlarmRise(hass.Hass):
def initialize(self):
self.mqtt_topic = "phone/alarm/{}".format(self.args["wakee"])
# self.log("mqtt | {}".format(self.mqtt_topic))
self.sensor = "sensor.mqtt_phone_alarm_{}".format(self.args["wakee"])
# self.log("sensor | {}".format(self.sensor))
self.light_name = "light.{}".format(self.args["wakee"])
# self.log("light | {}".format(self.light_name))
# self.sunrise_lights(self)
self.handle = self.listen_state(self.sunrise_lights, attribute = "state", entity_id = self.sensor, old = "")
self.log("LOG1 handle | {}".format(self.info_listen_state(self.handle)))
def sunrise_lights(self, entity_id, attribute, old_state, new_state, kwargs):
self.log("LOG2 entity | {}".format())
self.log("LOG£ call | {} {} {} {} {}".format(self, entity_id, attribute, old_state, new_state))
However, when the listen_state is triggered (by a change in one of the MQTT topics) it triggers both instances of ‘sunrise_lights’ not just the one for the instance that has actually had a state change.
The entity ID looks fine in LOG1 i.e. the entity_id (sensor.mqtt_phone_alarm_ben) matches the instance name (lights_alarm_rise_ben:), but when the listen state is triggered both instances are passed sensor.mqtt_phone_alarm_ben.
As far as my understanding goes, LOG3 should only be triggered for lights_alarm_rise_ben when the corresponding MQTT topic is updated.
Hope that makes some kind of sense.
Output:
2018-03-01 14:03:13.613455 INFO AppDaemon: Loading Object lights_alarm_rise_ben using class AlarmRise from module alarm_rise
2018-03-01 14:03:13.615410 INFO lights_alarm_rise_ben: LOG1 handle | ('default', None, 'state', {'entity_id': 'sensor.mqtt_phone_alarm_ben'})
2018-03-01 14:03:13.615545 INFO AppDaemon: Loading Object lights_alarm_rise_emma using class AlarmRise from module alarm_rise
2018-03-01 14:03:13.616332 INFO lights_alarm_rise_emma: LOG1 handle | ('default', None, 'state', {'entity_id': 'sensor.mqtt_phone_alarm_emma'})
2018-03-01 14:03:20.633378 INFO lights_alarm_rise_ben: LOG2 entity | sensor.mqtt_phone_alarm_ben
2018-03-01 14:03:20.634318 INFO lights_alarm_rise_emma: LOG2 entity | sensor.mqtt_phone_alarm_ben
2018-03-01 14:03:20.635047 INFO lights_alarm_rise_ben: LOG3 call | <alarm_rise.AlarmRise object at 0x7f8f30c6a6d8> sensor.mqtt_phone_alarm_ben state 1/3/2018 16:50
2018-03-01 14:03:20.636091 INFO lights_alarm_rise_emma: LOG3 call | <alarm_rise.AlarmRise object at 0x7f8f30c6ac50> sensor.mqtt_phone_alarm_ben state 1/3/2018 16:50
