With a RP2040, unless the ESPhome code uses the hardware CS function (which is very unusual as it limits the bus to a single SPI device) any legal pin will do.
The log, my apologies for not including it before.
The error is determined by zero values being returned when valid voltages are on MCP3008 pins.
INFO ESPHome 2026.3.1
INFO Reading configuration /config/esphome/txmon.yaml...
INFO Starting log output from 192.168.99.140 using esphome API
INFO Successfully resolved txmon @ 192.168.99.140 in 0.000s
INFO Successfully connected to txmon @ 192.168.99.140 in 0.005s
INFO Successful handshake with txmon @ 192.168.99.140 in 0.158s
[09:44:35.515][I][app:231]: ESPHome version 2026.3.1 compiled on 2026-03-29 18:06:46 +1100
[09:44:35.515][C][logger:229]: Logger:
[09:44:35.515][C][logger:229]: Max Level: DEBUG
[09:44:35.515][C][logger:229]: Initial Level: DEBUG
[09:44:35.515][C][logger:236]: Log Baud Rate: 115200
[09:44:35.515][C][logger:236]: Hardware UART: USB_CDC
[09:44:35.516][C][spi:066]: SPI bus:
[09:44:35.562][C][spi:152]: CLK Pin: GPIO2
[09:44:35.562][C][spi:152]: SDI Pin: GPIO0
[09:44:35.562][C][spi:152]: SDO Pin: GPIO3
[09:44:35.562][C][spi:074]: Using HW SPI: SPI
[09:44:35.562][C][i2c.arduino:064]: I2C Bus:
[09:44:35.562][C][i2c.arduino:065]: SDA Pin: GPIO4
[09:44:35.562][C][i2c.arduino:065]: SCL Pin: GPIO5
[09:44:35.562][C][i2c.arduino:065]: Frequency: 400000 Hz
[09:44:35.562][C][i2c.arduino:085]: Recovery: failed, SDA is held low on the bus
[09:44:35.562][I][i2c.arduino:089]: Results from bus scan:
[09:44:35.562][I][i2c.arduino:095]: Found device at address 0x44
[09:44:35.563][C][i2c.arduino:064]: I2C Bus:
[09:44:35.563][C][i2c.arduino:065]: SDA Pin: GPIO6
[09:44:35.563][C][i2c.arduino:065]: SCL Pin: GPIO7
[09:44:35.563][C][i2c.arduino:065]: Frequency: 400000 Hz
[09:44:35.563][C][i2c.arduino:085]: Recovery: failed, SDA is held low on the bus
[09:44:35.563][I][i2c.arduino:089]: Results from bus scan:
[09:44:35.563][I][i2c.arduino:091]: Found no devices
[09:44:35.563][C][status_led:018]: Status LED:
[09:44:35.563][C][status_led:152]: Pin: GPIO64
[09:44:35.563][C][mcp3008:016]: MCP3008:
[09:44:35.563][C][mcp3008:152]: CS Pin:GPIO18
[09:44:35.564][C][mcp3008:016]: MCP3008:
[09:44:35.566][C][mcp3008:152]: CS Pin:GPIO19
[09:44:35.586][C][mcp3008:016]: MCP3008:
[09:44:35.586][C][mcp3008:152]: CS Pin:GPIO20
[09:44:35.586][C][template.sensor:017]: Template Sensor 'db_trans_mpx'
[09:44:35.586][C][template.sensor:017]: State Class: ''
[09:44:35.586][C][template.sensor:017]: Unit of Measurement: 'dB'
[09:44:35.586][C][template.sensor:017]: Accuracy Decimals: 1
[09:44:35.586][C][template.sensor:453]: Update Interval: 2.0s
[09:44:35.607][C][template.sensor:017]: Template Sensor 'db_falcon_mpx'
[09:44:35.607][C][template.sensor:017]: State Class: ''
[09:44:35.607][C][template.sensor:017]: Unit of Measurement: 'dB'
[09:44:35.607][C][template.sensor:017]: Accuracy Decimals: 1
[09:44:35.607][C][template.sensor:453]: Update Interval: 2.0s
[09:44:35.607][C][template.sensor:017]: Template Sensor 'db_spare'
[09:44:35.607][C][template.sensor:453]: Update Interval: 1.0s
[09:44:35.637][C][sht4x:068]: SHT4x:
[09:44:35.637][C][sht4x:068]: Serial number: 0dbc9daa
[09:44:35.637][C][sht4x:073]: Address: 0x44
[09:44:35.637][C][mcp3008.sensor:011]: MCP3008Sensor:
[09:44:35.637][C][mcp3008.sensor:011]: Pin: 2
[09:44:35.637][C][mcp3008.sensor:011]: Reference Voltage: 3.30V
[09:44:35.637][C][mcp3008.sensor:011]: Pin: 3
[09:44:35.679][C][mcp3008.sensor:011]: MCP3008Sensor:
[09:44:35.679][C][mcp3008.sensor:011]: Pin: 4
[09:44:35.679][C][mcp3008.sensor:011]: Reference Voltage: 3.30V
[09:44:35.679][C][mcp3008.sensor:011]: Pin: 5
[09:44:35.679][C][mcp3008.sensor:011]: Pin: 6
[09:44:35.679][C][mcp3008.sensor:011]: Pin: 2
[09:44:35.720][C][mcp3008.sensor:011]: MCP3008Sensor:
[09:44:35.720][C][mcp3008.sensor:011]: Pin: 3
[09:44:35.720][C][mcp3008.sensor:011]: Reference Voltage: 3.30V
[09:44:35.720][C][mcp3008.sensor:011]: Pin: 4
[09:44:35.720][C][mcp3008.sensor:011]: Pin: 5
[09:44:35.720][C][mcp3008.sensor:011]: Pin: 6
[09:44:35.753][C][mcp3008.sensor:011]: MCP3008Sensor:
[09:44:35.753][C][mcp3008.sensor:011]: Pin: 2
[09:44:35.753][C][mcp3008.sensor:011]: Reference Voltage: 3.30V
[09:44:35.754][C][mcp3008.sensor:011]: MCP3008Sensor:
[09:44:35.754][C][mcp3008.sensor:011]: Pin: 3
[09:44:35.754][C][mcp3008.sensor:011]: Reference Voltage: 3.30V
[09:44:35.754][C][mcp3008.sensor:011]: Pin: 4
[09:44:35.754][C][mcp3008.sensor:011]: Pin: 5
[09:44:35.773][C][mcp3008.sensor:011]: MCP3008Sensor:
[09:44:35.773][C][mcp3008.sensor:011]: Pin: 6
[09:44:35.773][C][mcp3008.sensor:011]: Reference Voltage: 3.30V
[09:44:35.773][C][adc.rp2040:017]: ADC Sensor 'Trans MPX'
[09:44:35.773][C][adc.rp2040:017]: State Class: 'measurement'
[09:44:35.773][C][adc.rp2040:017]: Unit of Measurement: '%'
[09:44:35.773][C][adc.rp2040:017]: Accuracy Decimals: 1
[09:44:35.773][C][adc.rp2040:237]: Device Class: 'voltage'
[09:44:35.773][C][adc.rp2040:152]: Pin: GPIO26
[09:44:35.775][C][adc.rp2040:042]: Samples: 1
[09:44:35.775][C][adc.rp2040:042]: Sampling mode: average
[09:44:35.775][C][adc.rp2040:453]: Update Interval: 5.0s
[09:44:35.783][C][adc.rp2040:017]: ADC Sensor 'Falcon MPX'
[09:44:35.783][C][adc.rp2040:017]: State Class: 'measurement'
[09:44:35.783][C][adc.rp2040:017]: Unit of Measurement: '%'
[09:44:35.783][C][adc.rp2040:017]: Accuracy Decimals: 1
[09:44:35.783][C][adc.rp2040:237]: Device Class: 'voltage'
[09:44:35.784][C][adc.rp2040:152]: Pin: GPIO27
[09:44:35.797][C][adc.rp2040:042]: Samples: 1
[09:44:35.797][C][adc.rp2040:042]: Sampling mode: average
[09:44:35.797][C][adc.rp2040:453]: Update Interval: 2.0s
[09:44:35.797][C][adc.rp2040:017]: ADC Sensor 'SPARE'
[09:44:35.797][C][adc.rp2040:017]: State Class: 'measurement'
[09:44:35.797][C][adc.rp2040:017]: Unit of Measurement: '%'
[09:44:35.797][C][adc.rp2040:017]: Accuracy Decimals: 1
[09:44:35.798][C][adc.rp2040:237]: Device Class: 'voltage'
[09:44:35.802][C][adc.rp2040:152]: Pin: GPIO28
[09:44:35.802][C][adc.rp2040:042]: Samples: 1
[09:44:35.802][C][adc.rp2040:042]: Sampling mode: average
[09:44:35.802][C][adc.rp2040:453]: Update Interval: 1.0s
[09:44:35.824][C][wifi:1510]: WiFi:
[09:44:35.824][C][wifi:1510]: Local MAC: 28:CD:C1:03:AD:E0
[09:44:35.824][C][wifi:1510]: Connected: YES
[09:44:35.824][C][wifi:1221]: IP Address: 192.168.99.140
[09:44:35.824][C][wifi:1232]: SSID: [redacted]
[09:44:35.824][C][wifi:1232]: BSSID: [redacted]
[09:44:35.824][C][wifi:1232]: Hostname: 'txmon'
[09:44:35.824][C][wifi:1232]: Signal strength: -20 dB ▂▄▆█
[09:44:35.824][C][wifi:1232]: Channel: 6
[09:44:35.824][C][wifi:1232]: Subnet: 255.255.255.0
[09:44:35.824][C][wifi:1232]: Gateway: 192.168.99.1
[09:44:35.824][C][wifi:1232]: DNS1: 0.0.0.0
[09:44:35.824][C][wifi:1232]: DNS2: 0.0.0.0
[09:44:35.824][C][esphome.ota:071]: Over-The-Air updates:
[09:44:35.824][C][esphome.ota:071]: Address: 192.168.99.140:2040
[09:44:35.824][C][esphome.ota:071]: Version: 2
[09:44:35.826][C][esphome.ota:078]: Password configured
[09:44:35.842][C][safe_mode:026]: Safe Mode:
[09:44:35.842][C][safe_mode:026]: Successful after: 60s
[09:44:35.842][C][safe_mode:026]: Invoke after: 10 attempts
[09:44:35.842][C][safe_mode:026]: Duration: 300s
[09:44:35.842][C][api:237]: Server:
[09:44:35.842][C][api:237]: Address: 192.168.99.140:6053
[09:44:35.842][C][api:237]: Listen backlog: 1
[09:44:35.842][C][api:237]: Max connections: 4
[09:44:35.843][C][api:244]: Noise encryption: YES
[09:44:35.855][C][mdns:194]: mDNS:
[09:44:35.855][C][mdns:194]: Hostname: txmon
[09:44:36.358][D][sensor:124]: 'Falcon MPX' >> 0.3 %
[09:44:36.358][D][sensor:124]: 'db_falcon_mpx' >> -49.2 dB
[09:44:36.467][D][sensor:124]: 'SPARE' >> 0.4 %
[09:44:36.858][D][sensor:124]: 'db_spare' >> -48.6 dB
[09:44:36.858][D][sensor:124]: 'db_trans_mpx' >> -48.0 dB
[09:44:36.956][D][sensor:124]: 'STL Right' >> 0.00 %
[09:44:36.956][D][sensor:124]: 'TXA Fwd Pwr' >> 0.00 %
[09:44:36.958][D][sensor:124]: 'TXA Power Good' >> 0.00 %
[09:44:36.958][D][sensor:124]: 'TXB Refl Pwr' >> 0.00 %
[09:44:36.958][D][sensor:124]: 'TXB Fwd Pwr' >> 0.00 %
[09:44:37.469][D][sensor:124]: 'db_spare' >> -48.6 dB
[09:44:37.471][D][sensor:124]: 'SPARE' >> 0.4 %
[09:44:37.576][D][sensor:124]: 'STL Left' >> 0.00 %
[09:44:37.577][D][sensor:124]: 'TXB Power Good' >> 0.00 %
[09:44:37.577][D][sensor:124]: 'TXA IPA' >> 0.00 %
[09:44:37.746][D][sensor:124]: 'TXA VPA' >> 0.00 %
[09:44:37.746][D][sensor:124]: 'Trans MPX' >> 0.4 %
