Hi there.
I installed Home Assistant on a VM in Unraid and started to add my Devices. But i think i have some Problems with the Netatmo Configuration. I have 2 Indoor Cams, 1 Outdoor and 1 Doorbell. I only can see 1 Stream from one Indoor Camera. The others dont show anything. I made a Netatmo Dev Account for the Credentials that the Doorbell needs but also then no stream.
In the LOG i just found one entry…
File “/usr/src/homeassistant/homeassistant/components/netatmo/camera.py”, line 200, in stream_source
Versions:
Home Assistant 2022.11.2
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221108.0 - latest
Can someone help and / or explain?
