Multiple picture glance live feeds cause first stream to freeze
I use HA as a security monitoring entity in a tablet in my kitchen. For the layout I have 4 camera feeds that are setup with picture glance cards. As of the February release the 1st stream on the page will freeze. I can refresh the screen and it will grab a new image and then freeze again. Has anyone seen anything similar, or should I be seeing these cameras up with different cards? I’ve had this setup for at least 3 years without a problem. I’m not seeing anything in Lisa’s that is indicating a problem.
Make a dashboard with just one card for that camera to test it.
Restart the camera and see if that works.
The fact that three cameras work and one fails indicate more a failure with that specific camera.
Unless you have set up that camera different in HA, like selected another stream or similar.
Yeah I have gone through testing different cameras. No matter what camera I use at position 1 they always freeze. Same camera in position 2 works.
What happens if you put another card in position 1?
This is working properly after the most recent monthly release. This was really odd. I appreciate all the suggestions.
