Hi there. I have started my smart home journey a while ago and i have arrived at the point where I don’t like ready-made solutions for some of my wishes. I was wondering if it is possible to use a single ESP32 board with multiple platforms? For example i want to make an AC IR remote and Bluetooth proxy on the same device, since it is going to be constantly powered on, why not use it for something else So my question is if it is possible to combine those two, or any other integrations that don’t conflict with each other ?
I am not quite sure, if I understand your request correctly - but you should be able to use IR and BTProxy together, the same way as you can use “lights” together with Bluetooth and so on…
Here’s an example I am using on one of my model builds.
The esp is being used to illuminate parts on the model, but also acting as a BT Proxy at the same time.
If I add the hardware, it would also work as a thermometer / hygrometer… not an issue
esphome:
friendly_name: ${friendly_name}
comment: ${comment}
platformio_options:
board_build.flash_mode: dio
project:
version: ${project_version}
min_version: ${min_esp_version}
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xyz"
ota:
password: "xyz"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: $(wifi_hotspot_ssid)
password: $(wifi_hotspot_password)
captive_portal:
bluetooth_proxy:
active: true
# Wifi-Information
- platform: wifi_signal
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
# ESP Chip-Temperatur
- platform: internal_temperature
name: "Internal Temperature"
- platform: dht
model: dht11
pin: GPIO16
temperature:
name: "Temperature Living-Room"
humidity:
name: "Humidity Living-Room"
update_interval: 10s
# Device Uptime Information
- platform: uptime
update_interval: $wifi_update_interval
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
text_sensor:
# Wifi-Information
- platform: wifi_info
ip_address:
ssid:
bssid:
mac_address:
name: Mac Wifi Address
scan_results:
name: Latest Scan Results
name: Uptime Human Readable
icon: mdi:clock-start
binary_sensor:
# Touch-Sensor Switch
- platform: gpio
pin: GPIO04
filters:
- delayed_on: 5ms
on_press:
then:
- light.toggle: eyes_led
# Enable Buttons in HA UI
button:
- platform: restart
- platform: shutdown
name: "Mode: Dead London"
on_press:
then:
- light.turn_on:
effect: Dead London
- delay: 10s
- light.turn_off: eyes_led
light:
# Figure Eye-LED
- platform: monochromatic
output: eye_led
restore_mode: RESTORE_DEFAULT_OFF
effects:
- flicker:
alpha: 95%
intensity: 50%
# ESP Status LED
- platform: status_led
pin:
number: GPIO2
inverted: false
output:
- platform: ledc
pin:
number: GPIO26
Just look at some of the examples in the cookbook.
