Multiple remote transmitter
Hi everyone I want to realize two remote controllers in one project.One 433Mhz transmitter and one IR diode. The 433Mhz works, only the IR diode doesn’t. I guess it’s the syntax. Can someone help me? Thanks a lot
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "XXXX"
  password: "XXXXX"
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "XXXX"
ota:
  password: "XXXX"
# BME280 Temperature+Pressure+Humidity Sensor
i2c:
  scl:  D5
  sda:  D4
  scan: true
# 433Mhz Steckdose
remote_transmitter:
  - id: Mhz
    pin: D3
    # RF uses a 100% carrier signal
    carrier_duty_percent: 100%
  - id: IR
    pin: D2
  - platform: bme280
    temperature:
      name: "Wohnzimmer Temperature"
      oversampling: 16x
    pressure:
    humidity:
    address: 0x76
    update_interval: 60s
switch:
  # Relaise
  - platform: gpio
    pin: D1
    name: "Garage Door Open Switch"
  - platform: gpio
    pin: D6
    name: "Garage Door Close Switch"
  - platform: gpio
    pin: D7
    name: "Garage Door Stopp"
  #Steckdosen
    turn_on_action:
      - remote_transmitter.transmit_rc_switch_raw:
          protocol: 4
          code: '110101001111110100110000'
          repeat:
            times: 10
    turn_off_action:
          protocol: 4
          code: '110111101000101100100000'
          repeat:
            times: 10
    turn_on_action:
          protocol: 4
          code: '110101001111110100110100'
          repeat:
            times: 10
    turn_off_action:
          protocol: 4
          code: '110110101101111100010100'
          repeat:
            times: 10
    turn_on_action:
          protocol: 4
          code: '110101001111110100111100'
          repeat:
            times: 10
    turn_off_action:
          protocol: 4
          code: '110110101101111100011100'
          repeat:
            times: 10
    turn_on_action:
          protocol: 4
          code: '110110101101111100010010'
          repeat:
            times: 10
    turn_off_action:
          protocol: 4
          code: '110101001111110100110010'
          repeat:
            times: 10
#IR Fernbedienung
    turn_on_action:
      - remote_transmitter.transmit_samsung:
          data: 0xE0E040BF
  #//Samsung AN/AUS
#irsend.sendSAMSUNG(0xE0E040BF, 32);
#delay(50);}
#void TVLauter(){
#  //Samsung Lauter
#  irsend.sendSAMSUNG(0xE0E0E01F, 32);
#  delay(50); }
#void TVLeiser(){
#  //Samsung Leiser
#  irsend.sendSAMSUNG(0xE0E0D02F, 32);
#  delay(50);}
#void TVSmart(){
#  //Samsung Smart
#irsend.sendSAMSUNG(0xE0E09E61, 32);
#delay(3000);
#//Samsung Rechts
#irsend.sendSAMSUNG(0xE0E046B9, 32);
#delay(3000);
#//Samsung Enter
#irsend.sendSAMSUNG(0xE0E016E9, 32);
#delay(50);  }
#void TVBack() {
#  //Samsung Internet Zurück
#  irsend.sendSAMSUNG(0xE0E008F7, 32);
#  delay(50); }
cover:
  # Relaise
    open_action:
      # Cancel any previous action
      - switch.turn_on: close_switch
      # Turn the OPEN switch on briefly
      - switch.turn_off: open_switch
      - switch.turn_on: stopp_switch
      - delay: 0.1s
      - switch.turn_on: open_switch
    close_action:
      - switch.turn_off: close_switch
      - delay: 0.1s
    stop_action:
      - switch.turn_off: stopp_switch
      - delay: 0.1s
    optimistic: true
    assumed_state: true
    # Steckdose
    open_action:
      - switch.turn_on: A
    close_action:
      - switch.turn_off: A
    optimistic: true
    assumed_state: true
    open_action:
      - switch.turn_on: B
    close_action:
      - switch.turn_off: B
    optimistic: true
    assumed_state: true
    open_action:
      - switch.turn_on: C
    close_action:
      - switch.turn_off: C
    optimistic: true
    assumed_state: true
    open_action:
      - switch.turn_on: D
    close_action:
      - switch.turn_off: D
    optimistic: true
    assumed_state: true
I am a complete novice - just reading the docs - but I wonder if you copy pasted the RF for IR and need to change a value. Reading the ESPHome documentation for remote_transmitter it says:
Carrier_duty_percent (Optional, int): ... Set this is 50% if you’re working with IR leds and to 100% if working with a other things like 433MHz transmitters.
I haven’t worked with these devices are all yet, but a simple check would be to change the percentage for the IR to 50% per the documents on ESPHome.io and see if that is the culprit.
Cheers!
DeadEnd
Thank you so much for pointing that out. I have set the value to 50%. IR is still not working. I don’t know how to access the different ID´s at the remote_transmitter. I assume that only the first ID Mhz is processed.
Ah good point!
here it is:
  • transmitter_id ( Optional , ID): The remote transmitter to send the remote code with. Defaults to the first one defined in the configuration.
So I think this will fix it:
#IR Fernbedienung
    turn_on_action:
          transmitter_id: IR
          data: 0xE0E040BF
I think that is in the correct place :slight_smile:
Cheers!
DeadEnd
That’s it. Thank you very much.
