Multiple Repetier Servers
Has anyone successfully connected more than 1 Repetier Server installations? I keep trying but get an error that I am duplicating.
The system cannot restart because the configuration is not valid: Invalid config for [repetier]: contains duplicate items: [‘repetierserver’] for dictionary value @ data[‘repetier’]. Got [OrderedDict([(‘host’, ‘192.168.20.36’), (‘api_key’, ‘XXXXX155-d5e0-4e84-9c49-06f67e5XXXXX’), (‘sensors’, OrderedDict([(‘monitored_conditions’, [‘current_state’, ‘current_job’, ‘extruder_temperature’, ‘bed_temperature’])]))]), OrderedDict([(‘host’, ‘192.168.20.38’), (‘api_key’, ‘XXXXX14c-7f75-4e8e-8c25-d35a955XXXXX’), (‘port’, 3344)])]. (See /config/configuration.yaml, line 420).
Here is what I have:
repetier:
  - host: 192.168.20.36
    api_key: XXXXX155-d5e0-4e84-9c49-06f67e5XXXXX
    sensors:
      monitored_conditions:
        - 'current_state'
        - 'current_job'
        - 'extruder_temperature'
        - 'bed_temperature'
  - host: 192.168.20.38
    api_key: XXXXX14c-7f75-4e8e-8c25-d35a955XXXXX
    port: 3344
which matches the documentation (unless I am severely overlooking something):
repetier:
  - host: REPETIER_HOST
    api_key: YOUR_API_KEY
    sensors:
        - 'current_state'
        - 'current_job'
    port: 3344
Both servers are up, cameras are configured in HA and printers are on & running on both servers.
Any ideas? Appears to either be broken integration or some syntax issue. Users are created on both servers and API codes have been refreshed and verified.
