Multiple sites/locations
What is the preferred way of using Home Assisant with multiple locations, for example the home in the city and the summer house. I would like to monitor/control things in both locations, and at least be able to monitor/control the summer house from home.
Is there any mechanism in place for this?
Currently I am running one Home Assistant instance at each location.
The sensors/controls that rely on external online service, I can add to both instances.
Is there any way of getting the instances to communicate with each other?
Can events/commands be published using MQTT somehow?
Any thoughts on this?
sorry, I just discovered home-assistant.io/developers/ar … -instances
Also in the next version is this: github.com/balloob/home-assistant/pull/882
perfect, mqtt-eventstream is exactly what I need!
