I’m looking to to exactly what was asked here but the solution is not really a solution.
I have multiple rooms in my house, each with a TRVZB TRV on the radiator. I want each room to be able to ask for heat from the heater until the temperature sensor reaches its target.
If I configure multiple thermostats with the same real switch when two or more rooms ask for heat, the heat would be turned off when the first one reaches the target temp - I want to avoid this.
In my mind I need to:
- Create a virtual switch for each room like
switch.room1,switch.room2 - Create a generic thermostat for each room
climate.room1,climate.room2which control their respective switches - Create a virtual template switch that turns on/off the real switch:
switch:
switches:
combined_heater:
value_template: >
{{ is_state('climate.room1', 'heating')
or is_state('climate.room2', 'heating') }}
turn_on:
service: switch.turn_on
entity_id: switch.real_switch
turn_off:
service: switch.turn_off
This is not hard to do, but it seems too complicated. Does anyone know of a cleaner way to achieve this?
Thanks!
