Multiple triggers and multiple actions in one automation
I have made the HALO air quality sensor and is working just great with home assistant. Now I want the LED ring light up when the CO2 is low (green) medium (orange) or high (red).
is it possible to do this within one single automation and how can I turn off the led when it is within a specific range?
thnx for the help.
You can run the whole world with a single automation if you wanted (, although it would probably be a bad design decision).
You should post some more information, along with code that you’d tried, or the best most people here can do is point you to The Documentation.
thx for the help
I now have this yaml file but I don’t know how to integrate the trigger ID into a specific action:
alias: Light 'Turn on on Halo Air Quality Sensor Halo
description: ""
triggers:
  - trigger: numeric_state
    entity_id:
      - sensor.halo_v1_co2
    below: 800
    entity_id:
    above: 801
    below: 1100
    entity_id:
    above: 1091.2
conditions: []
actions:
  - action: light.turn_on
    metadata: {}
      rgb_color:
        - 255
        - 38
        - 0
      transition: 5
      entity_id:
        - light.halo_v1_halo
mode: single
thnx
I have tested an automation where i have used the choose action for selecting the trigger id:
alias: timer test trigger
description: ""
triggers:
  - trigger: time
    at: input_datetime.time2trigerevent
  - trigger: time
    at:
      entity_id: input_datetime.time2trigerevent
      offset: "00:00:30"
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - time-1
        sequence:
          - action: switch.turn_on
            metadata: {}
            data: {}
              entity_id: switch.esp32_s3_relay_6ch_relay_1
      - conditions:
            id:
              - time-2
        sequence:
          - action: switch.turn_off
            metadata: {}
            data: {}
mode: single
description: ""
triggers:
    entity_id:
    below: 800
    entity_id:
    above: 801
    below: 1100
    entity_id:
    above: 1091.2
conditions: []
actions:
    metadata: {}
      color_name: "{{ trigger.id }}"
      transition: 5
      entity_id:
mode: single
Reference
light.turn_on
Looks so simple… :wink: why can’t I think of it…
going to test this asap
thnx
Looks like it is working… superb!
thnx all for the help
If 123’s answer works for you, please consider scrolling up to it and marking it as a Solution.
This will help other readers of the forum who might be searching for the same answer. Thank you!
I have just one question and don’t know how to solve this using this config.
I have setup the brightness to 30%
      brightness_pct: 30
Now I only want for the red light to have a brightness of 100%, is this something I have to setup in conditions or can It be done in the action itself?
actions:
    metadata: {}
      brightness_pct: "{{ iif(trigger.id == 'red', 100, 30) }}"
      transition: 5
      entity_id:
Reference
Templating - Immediate If
It all looks so simple… ;:
