Multiply Modbus values
I would like to multiply two values that I get when I query about EPEVER inverter.
My configuration.yaml is :
modbus:
  • name: Epever
    delay: 5
    close_comm_on_error: true
    retry_on_empty: true
    retries: 10
    type: serial
    baudrate: 115200
    bytesize: 8
    method: rtu
    parity: N
    port: /dev/ttyACM0
    stopbits: 1
    sensors:
    Utility
    • name: “Courant de sortie onduleur”
      unit_of_measurement: A
      slave: 10
      address: 0x3522
      input_type: input
      scale: 0.01
      precision: 2
    • name: “Tension de sortie onduleur”
      unit_of_measurement: V
      slave: 10
      address: 0x3521
      input_type: input
      scale: 0.01
      precision: 2
I tried with this :
     name: "Puissance de sortie"
     unit_of_measurement: "VA"
     device_class: energy
     state_class: total
     state: '{{ ((state(sensor.courant_ondule) | float) * (state(sensor.tension_de_sortie_onduleur) | float)) | round(0) }}'
     unique_id: "Puissance de sortie"
but it doesn’t work, i have “unavailable”
Can you help me please ?
states('sensor.eb3_power_factor')|float(0)
like this ?
 state_class: total
 state: '{{ ((states('sensor.courant_ondule') | float(0)) * (states('sensor.tension_de_sortie_onduleur') | float(0))) | round(0) }}'
Thanks.
Now I have an error with the code proposal :
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/configuration.yaml”, line 204, column 9
expected , but found ‘’
in “/config/configuration.yaml”, line 208, column 30
The line 208 is :
state: "{{ ((states('sensor.courant_ondule') | float(0)) * (states('sensor.tension_de_sortie_onduleur') | float(0))) | round(0) }}"
It’s perfect! it works! Thank you very much!
