Multizone Media Controller with AppDaemon
Home Assistant Multizone Media Player Controller
hacs_badge
Multizone Media Player Controller app for AppDaemon.
This creates a sensor that represents the current media_player zone that is under control.
e.g. You have a reciever with 3 zones. When brought into Home Assistant, you get 3 separate Zones. You’d like to turn the volume up for all the zones that are on, or optionally just turn on one.
  • The created sensors current state will represent which zones are on. e.g. All Zones, Zone 1, Zone 2, Zone 1, Zone 1,2, off.
  • The sensor will contain a list of available media_players (All players that are currently on).
  • The sensor will contain a list of active media_players (All players that will be affected by the events).
Installation
Download the multizone_media_control directory from inside the apps directory to your local apps directory, then add the configuration to enable the hacs module.
Example App configuration
Basic
# Creates a controller that will cycle between Zone 1, Zone 2, and All Zones (when all are on).
zone1_volume:
  module: convert_media_volume
  class: ConvertMediaVolume
  media_players:
  - media_player.yamaha_receiver
  - media_player.yamaha_receiver_zone_2
Advanced
# The volume will only increase and decrease on every 0.05 level.
multizone_controller:
  module: multizone_media_control
  class: MultiZoneController
  media_players:
  snap_volume: true
  volume_increment: 0.05
  volume_max: 1.0
  volume_min: 0.2
App Configuration
key optional type default description
module False string multizone_media_control The module name of the app.
class False string MultiZoneController The name of the Class.
media_players False list list of media_player entity_ids.
name True str Active Media Player Friendly name of the Sensor.
volume_max True float 1.0 A maximum volume that the controller can go to. range(0.51 - 1.25)
volume_min True float 0.0 A minimum volume that the controller can go to. range(0.0 - 0.5)
volume_increment True float 0.01 The amount of volume that moves up and down when a volume_up/down event is detected.
snap_volume True bool False When this is active, the volume will snap to the volume increment. Meaning if you have an increment of 0.5, the volume will only increase to all numerical values that are devisible by 0.05. I.e. 0.0, 0.05, 0.10, 0.15, etc.
event_id True str multizone The event_id used in event data for an event service call.
log_level True 'INFO' | 'DEBUG' 'INFO' Switches log level.
Recommended Setup
App configuration.
zone1_volume:
  media_players:
Scripts.yaml
multizone_volume_up:
  sequence:
  - event: mz_volume_up
    event_data:
      event_id: multizone
multizone_volume_down:
  sequence:
  - event: mz_volume_down
    event_data:
      event_id: multizone
multizone_volume_mute:
  sequence:
  - event: mz_volume_mute
    event_data:
      event_id: multizone
multizone_cycle_zone:
  sequence:
  - event: mz_cycle_zone
    event_data:
      event_id: multizone
multizone_volume_set:
  sequence:
  - event: mz_volume_set
    event_data_template:
      event_id: multizone
      volume_level: "{{ volume_level }}"
calling the scripts
  # VOLUME UP
  - service: script.multizone_volume_up
  # VOLUME DOWN
  - service: script.multizone_volume_down
  # VOLUME MUTE
  - service: script.multizone_volume_mute
  # CYCLE ZONES
  - service: script.multizone_cycle_zone
  # VOLUME SET
  - service: script.multizone_volume_set
      volume_level: 0.5
Suggestions
I am open with suggestions. I don’t know if AppDaemon can create a media player and work properly. But I can add an option’s list to the sensor and pair it with an set_option event. This would allow you to make an input select instead of using a script. As I said, I’m open to any suggestion. Ask and you may recieve.
My Setup
The left button cycles the zones, the volume up/down/mute will perform that action on the displayed zone.
I just had a quick go at setting up a group of Sonos players in a zone however could manage to get them to appear as available. Not sure what I was doing wrong OR if it was because I am using AppDaemon 4.
I’m running Appdaemon 4 and it’s working on my system. What’s not working for you?
Hello, I’m quite new to the app in HA, could you please help me to setting up this App?
Where should I enter the App configuration details? is it a separate Yaml file ?
Carmelo
Hello, welcome to the community.
This is just an automation, it does not create the buttons in the image you see above. It requires AppDaemon and HACS. Do you have those installed yet?
Thanks, yes I have both installed and I copied also already the Multizone media controller folder to my app directory.
I already have also apps.yaml file should I set the configuration parameter in this file?
