Regarding the global presets, I’m not sure what you mean by “incomplete.”
PHASE 2 — Architectural Evolution (In Progress)
- Virtual Thermostats via UI: Automatic creation of
climateentities from a temperature sensor and a simple switch (e.g., bare relays) without YAML.- Global Presets (Dynamic Memory): Presets (Manual / Eco / Comfort / Sleep / Away) act as “global scenes” with dynamic memory per individual zone.
How do i use this?
With heating on demand i mean randomly used rooms → sort of presence per room using a switch.
I dont use person trackers and i dont think its useful to start heating on arrival.
You are right regarding my boiler. It could be managed by a room thermostate, but i dont have one (main room is the most warm one).
It would be nice if your integration could set the boiler climate temperature or provide a number entity i can use in an automation.
There are a lot of heating projects. I tried several of them, but i not yet found one i could use without glitches.
I cannot use some of them together, as most of them work by changing TRV temperatures → settings war.
They have no scheduling or no heat adaption or dont tell my boiler what to do.
The one calculating preheat time does it only for morning heating, but i need it for the cold room used in evenings too. Especially on not so cold sunny days heating stays off around warm hours, but the cold room facing west gets colder then its eco temperature and needs early heating start. Or the warm rooms get overheated (non-isolated pipes, cold room is the last one).
Comfort is 2°C over Eco (not used, not home, night).
I would like to get rid of my several different not so optimal automations and the need to adapt settings on changing weather. Why else i have a SMART home system ![]()
Some of the tried ones:
Currently used with several added automations.
I can add several schedules per room like kitchen_normal, kitchen_holiday, kitchen xyz and i can switch between them by a global select using normal, holiday, xyz
Analytics only
Versatile Thermostat looks like it has evolved, i need to reevaluate it
Just found RoomMind, looks very interesting too
