Mumble server addon? Is this available?
Can I install a mumble server on my home assistant via an addon? I originally had it running on a raspberry pi that also ran Raspbian and a docker image of home assistant but now that I’m running home assistant natively that isn’t really possible I don’t think, anyone know if this is possible? Like an addon that is a mumble server?
Did you endup trying to install it on the same Raspberry you run Home Assistant ? Is it working ?
It actually did work but I tried to change the password for the user pi and then couldn’t log in and just reformatted it and used it for something else and got an odroid n2+
