Mushroom-template-chips: How to change Text Color?
Please try this…
icon_color: >
  {% set k =  states('sensor.presa_multimediale_cucina_power')| int (0) %}
    {% set d = states[switch.presa_multimediale_cucina'].state %}
    {% if (k >= 20 and d == 'on')  %} green
    {% elif (d  == 'off')  %} red
    {% else %}
    grey
    {% endif %}
no…
It works well only with the socket turned on and consumption below 20W
with consumption above 20W it still remains gray and not green as I would like
with the socket off the icon does not turn red
I feel guilty for asking such a seemingly silly question, but I realize it’s very peculiar
I’ll post the complete code to make sure I haven’t made any mistakes:
type: custom:stack-in-card
mode: vertical
cards:
  - type: custom:stack-in-card
    mode: horizontal
    cards:
        primary: Presa Multimediale Cucina
        secondary: '{{states.sensor.presa_multimediale_cucina_power.state}} W'
        icon: >-
          {% if is_state(entity, 'off') %} mdi:power-plug-off-outline {%- else
          -%} mdi:power-plug-outline {% endif %}
        icon_color: >
         {% else %}
         grey
         {% endif %}
        fill_container: true
        layout: vertical
        tap_action:
          action: more-info
        entity: switch.presa_multimediale_cucina
        multiline_secondary: truee;
        card_mod:
          style: >
            ha-card { {% set power =
            states('sensor.presa_multimediale_cucina_power') | float%} {% if
            power <= 0 %} --card-primary-color:grey;--card-secondary-color:grey;
            {% elif power < 100 %}
            --card-primary-color:white;--card-secondary-color:green; {% elif
            power < 200 %}
            --card-primary-color:white;--card-secondary-color:lime; {% elif
            power < 500 %}
            --card-primary-color:white;--card-secondary-color:yellow; {% elif
            power < 800 %}
            power < 1000 %}
            power < 1500 %}
            --card-primary-color:white;--card-secondary-color:orange; {% else %}
            --card-primary-color:white;--card-secondary-color:red; {% endif
sorry missed a single quote.
mode: vertical
cards:
    mode: horizontal
    cards:
        icon: >-
        icon_color: >
         {% set d = states('switch.presa_multimediale_cucina') %}
         {% else %}
         grey
         {% endif %}
        layout: vertical
        tap_action:
          action: more-info
        card_mod:
          style: >
            power < 200 %}
            power < 500 %}
            power < 800 %}
            power < 1000 %}
            power < 1500 %}
Top!!!
Awesome!!! Glad we got it.
This should work, but I was a little confused on the colors. We may be able to shorten the code up because you have multiple stages with the same color scheme
The error was result of the integer not being clearly defined
card_mod:
      style: |
        ha-card {
          {% set e = states('sensor.presa_multimediale_cucina_power') | int(0)  %}
            {% if (e | int(0) <= 0 ) %} --card-primary-color:white;--card-secondary-color:red
            {%  elif (e | int(0) <= 100 ) %} --card-primary-color:white;--card-secondary-color:green
            {%  elif (e | int(0) <= 200 ) %} --card-primary-color:white;--card-secondary-color:lime
            {%  elif (e | int(0) <= 500 ) %} --card-primary-color:white;--card-secondary-color:yellow
            {%  elif (e | int(0) <= 800 ) %}  --card-primary-color:white;--card-secondary-color:yellow
            {%  elif (e | int(0) <= 1000 ) %} --card-primary-color:white;--card-secondary-color:yellow
            {%  elif (e | int(0) >= 1500 ) %} --card-primary-color:white;--card-secondary-color:orange
            {% else %}
            {% endif %}
