Music Assistant 2.10: AI dj not working
Trying out the AI dj in Music Assistant. The selected playlist is being played, but the dj voice is never heard.
I got this in the logging:
2026-09-05 15:15:34.367 WARNING (MainThread) [music_assistant.AI Radio] AI Radio clip 802a49e13bb74abcab91d8d6453ce00f_002 (Artist fact) failed to generate: AI engine 'hass/ai_task.ollama_ai_task' is not connected. Reconnect the provider (for example Home Assistant) and retry.
2026-09-05 15:15:34.368 WARNING (MainThread) [music_assistant.streams.audio] AI Radio clip 802a49e13bb74abcab91d8d6453ce00f_002 failed to generate
2026-09-05 15:15:34.368 WARNING (MainThread) [music_assistant.player_queues] Skipping unplayable item Artist fact (ai_radio://sound_effect/802a49e13bb74abcab91d8d6453ce00f_002): Unable to retrieve streamdetails for Artist fact (ai_radio://sound_effect/802a49e13bb74abcab91d8d6453ce00f_002)
My configuration of the Music Nerd host is as follows:
The AI DJ plugin is configured this way:
I’ve used both local LLM’s (Ollama) and Google Gemini. Both give the same error: (Artist fact) failed to generate: AI engine ‘hass/ai_task.ollama_ai_task’ is not connected. Reconnect the provider (for example Home Assistant) and retry.
I have no idea how to follow this advice. It worked when using the beta version of MA. Have removed this version of MA when 2.10 stable came out.
Anyone has a solution to correct this error or knows how to debug this problem? If necessary I can provide more logging.
You *might* want to ask here…
[Music assistant]( Music Assistant 2.0: Your Music, Your Players )
The people that are watching that thread are all either interested. users of, or authors of Music Assistant.
They are likely your best resource.
Also there is a Discord: Music Assistant
Ah, thank you. I’ll close this thread then.
