Music assistant error Player does not support enqueueing - work around?
apparently not many people are running into this as my searches have been so far fruitless but for us using music assistant about every 5-10min it stops on the player we are using (an old fire 7 with fully kiosk ) and particularly on a radio stream.
error which get repeated various numbers of times:
music_assistant_models.errors.UnsupportedFeaturedException: Player Fire Tablet does not support enqueueing
2025-03-07 19:50:35.872 ERROR (MainThread) [music_assistant] Error doing task: Task exception was never retrieved
  File "/app/venv/lib/python3.12/site-packages/music_assistant/controllers/player_queues.py", line 1454, in _enqueue_next_item
    await self.mass.players.enqueue_next_media(
  File "/app/venv/lib/python3.12/site-packages/music_assistant/controllers/players.py", line 766, in enqueue_next_media
    raise UnsupportedFeaturedException(
in trouble shooting if the device supports “flow mode” which i have not found more info on then maybe it would work and some reference to a player compatibility list which I think is this: Player Support - Music Assistant (?)
seems the player does not apparently support enqueueing … so what is one to do?
well I just found a dirty band aid - the following automation at least keeps us from having to press play every 5min or so
automation code if someone is interested, just was a ui built automation but glad it worked!
alias: on radio idle play
description: ''
triggers:
  - device_id: a20_insertyourshere
    domain: media_player
    entity_id: 3356sss_insertyourshere
    type: idle
    trigger: device
conditions:
  - condition: state
    entity_id: input_boolean.created_switch_to_just_have_it_play_this_forever
    state: "on"
actions:
  - action: music_assistant.play_media
    metadata: {}
      media_id: radio channel you want to play
      enqueue: play
      media_type: radio
      device_id: 338e8a_insertyourshere
mode: single
it takes a few seconds when it replays but certainly there is a better solution?
hopefully there is before I start building out the automation (if possible ?) to check if it was on radio then to play the same thing or a playlist to play the next song. . seems like I am building an assistant to the music assistant :upside_down_face:
Hello Patrch,
You might want to ask one of these places…
Music assistant
The people that are watching that thread are all either interested. users of, or authors of Music Assistant.
They are likely your best resource.
Also there is a Discord: Music Assistant
thanks! i added it to that thread!
What player provider have you added this with? Have you looked in the player settings to see if flow mode is available and on if so?
yes it does not seem to support it.
what i think is strange is that it works fine with playlists (eg from spotify) which i guess is a type of enqueueing but radio streaming seems to be a bit odd and that does not seem to work.
Again what player provider is this? Is it the fully kiosk provider?
yes it is a fire 7 running it through fully kiosk
I’m seeing a problem but not the same as yours. What version of the server are you running?
music assistant server: 2.4.4
Issue raised here Fully Kiosk player stops when playing radio stream · Issue #3703 · music-assistant/support · GitHub
wow thankyou!!
The devs are having trouble reproducing this. Can you try 2.5.0b12 and see if this is still a problem. After updating then do the minimum necessary to get the problem to occur then go to MA SETTINGS>>CORE and download the log from there and drag and drop it here
here you go
log
2025-03-12 10:34:09.617 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Chromecast
2025-03-12 10:34:09.756 DEBUG (MainThread) [music_assistant] Loaded manifest for provider ListenBrainz Scrobbler
2025-03-12 10:34:09.787 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Fully Kiosk Browser
2025-03-12 10:34:09.795 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Playergroup
2025-03-12 10:34:09.809 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Music Assistant
2025-03-12 10:34:09.814 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Airplay
2025-03-12 10:34:09.847 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Filesystem (local disk)
2025-03-12 10:34:09.868 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Home Assistant MediaPlayers
2025-03-12 10:34:09.949 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Deezer
2025-03-12 10:34:09.962 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Qobuz
2025-03-12 10:34:09.986 DEBUG (MainThread) [music_assistant] Loaded manifest for provider The Audio DB
2025-03-12 10:34:10.011 DEBUG (MainThread) [music_assistant] Loaded manifest for provider MusicBrainz
2025-03-12 10:34:10.070 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Audible
2025-03-12 10:34:10.102 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Bluesound
2025-03-12 10:34:10.133 DEBUG (MainThread) [music_assistant] Loaded manifest for provider SiriusXM
2025-03-12 10:34:10.139 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Soundcloud
2025-03-12 10:34:10.180 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Spotify
2025-03-12 10:34:10.232 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Open Subsonic Media Server Library
2025-03-12 10:34:10.278 DEBUG (MainThread) [music_assistant] Loaded manifest for provider YouTube Music
2025-03-12 10:34:10.319 DEBUG (MainThread) [music_assistant] Loaded manifest for provider UPnP/DLNA Player provider
2025-03-12 10:34:10.349 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Tune-In Radio
2025-03-12 10:34:10.395 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Spotify Connect
2025-03-12 10:34:10.424 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Jellyfin Media Server Library
2025-03-12 10:34:10.446 DEBUG (MainThread) [music_assistant] Loaded manifest for provider SONOS S1
2025-03-12 10:34:10.460 DEBUG (MainThread) [music_assistant] Loaded manifest for provider RadioBrowser
2025-03-12 10:34:10.486 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Snapcast
2025-03-12 10:34:10.497 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Filesystem (remote share)
2025-03-12 10:34:10.513 DEBUG (MainThread) [music_assistant] Loaded manifest for provider iBroadcast
2025-03-12 10:34:10.538 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Audiobookshelf
2025-03-12 10:34:10.575 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Apple Music
2025-03-12 10:34:10.610 DEBUG (MainThread) [music_assistant] Loaded manifest for provider fanart.tv
2025-03-12 10:34:10.627 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Plex Media Server Library
2025-03-12 10:34:10.676 DEBUG (MainThread) [music_assistant] Loaded manifest for provider iTunes Podcast Search
2025-03-12 10:34:10.695 DEBUG (MainThread) [music_assistant] Loaded manifest for provider SONOS
2025-03-12 10:34:10.715 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Music Assistant
2025-03-12 10:34:10.734 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Home Assistant
2025-03-12 10:34:10.754 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Podcast RSS Feed
2025-03-12 10:34:10.766 DEBUG (MainThread) [music_assistant] Loaded manifest for provider LastFM Scrobbler
2025-03-12 10:34:10.774 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Tidal
2025-03-12 10:34:10.781 DEBUG (MainThread) [music_assistant] Loaded manifest for provider Squeezelite (slimproto players)
2025-03-12 10:34:10.809 DEBUG (MainThread) [music_assistant.controllers.config] Loaded persistent settings from /data/settings.json
2025-03-12 10:34:10.816 DEBUG (MainThread) [music_assistant.controllers.config] Started.
2025-03-12 10:34:10.833 INFO (MainThread) [music_assistant] Starting Music Assistant Server (2cfa6dfb3729453b82912769b7c70abd) version 2.5.0b12 - HA add-on: True - Safe mode: False
2025-03-12 10:34:10.886 INFO (MainThread) [music_assistant.cache] Initializing cache controller...
2025-03-12 10:34:11.368 DEBUG (MainThread) [music_assistant.cache] Compacting database...
2025-03-12 10:34:11.375 DEBUG (MainThread) [music_assistant.cache] Compacting database done
2025-03-12 10:34:11.380 DEBUG (MainThread) [music_assistant.cache] Running automatic cleanup...
2025-03-12 10:34:11.426 DEBUG (MainThread) [music_assistant.cache] Automatic cleanup finished (cleaned up 0 records)
2025-03-12 10:34:11.435 INFO (MainThread) [ffmpeg] Detected ffmpeg version 7.1 with libsoxr support
2025-03-12 10:34:11.472 INFO (MainThread) [music_assistant.streams] Starting server on  0.0.0.0:8097 - base url: http://192.168.1.110:8097
2025-03-12 10:34:13.865 DEBUG (MainThread) [music_assistant.music] Compacting database...
2025-03-12 10:34:13.884 DEBUG (MainThread) [music_assistant.music] Compacting database done
2025-03-12 10:34:13.884 INFO (MainThread) [music_assistant.music] Using a sync interval of 720 minutes.
2025-03-12 10:34:13.893 DEBUG (MainThread) [music_assistant.metadata] Start lookup for missing artist images...
2025-03-12 10:34:13.901 DEBUG (MainThread) [music_assistant.metadata] Start lookup for missing album images...
2025-03-12 10:34:13.970 INFO (MainThread) [music_assistant.webserver] Starting server on  172.30.32.1:8095 - base url: http://172.30.32.1:8095
2025-03-12 10:34:13.979 DEBUG (MainThread) [music_assistant] Starting Zeroconf broadcast...
2025-03-12 10:34:15.145 DEBUG (MainThread) [music_assistant.webserver] Handling command providers
2025-03-12 10:34:15.183 DEBUG (MainThread) [music_assistant.webserver] Handling command providers/manifests
2025-03-12 10:34:15.197 DEBUG (MainThread) [music_assistant] Loading provider player_group
2025-03-12 10:34:15.200 DEBUG (MainThread) [music_assistant] Loading provider builtin_player
2025-03-12 10:34:15.203 DEBUG (MainThread) [music_assistant] Loading provider theaudiodb
2025-03-12 10:34:15.206 DEBUG (MainThread) [music_assistant] Loading provider musicbrainz
2025-03-12 10:34:15.209 DEBUG (MainThread) [music_assistant] Loading provider fanarttv
2025-03-12 10:34:15.213 DEBUG (MainThread) [music_assistant] Loading provider builtin
2025-03-12 10:34:15.233 DEBUG (MainThread) [music_assistant.player_group] Log level configured to GLOBAL
2025-03-12 10:34:15.235 INFO (MainThread) [music_assistant] Loaded player provider Playergroup
2025-03-12 10:34:15.240 DEBUG (MainThread) [music_assistant.builtin_player] Log level configured to GLOBAL
2025-03-12 10:34:15.242 INFO (MainThread) [music_assistant] Loaded player provider Music Assistant
2025-03-12 10:34:15.249 DEBUG (MainThread) [music_assistant.theaudiodb] Log level configured to GLOBAL
2025-03-12 10:34:15.250 INFO (MainThread) [music_assistant] Loaded metadata provider The Audio DB
2025-03-12 10:34:15.256 DEBUG (MainThread) [music_assistant.musicbrainz] Log level configured to GLOBAL
2025-03-12 10:34:15.257 INFO (MainThread) [music_assistant] Loaded metadata provider MusicBrainz
2025-03-12 10:34:15.262 DEBUG (MainThread) [music_assistant.fanarttv] Log level configured to GLOBAL
2025-03-12 10:34:15.263 INFO (MainThread) [music_assistant] Loaded metadata provider fanart.tv
2025-03-12 10:34:15.272 DEBUG (MainThread) [music_assistant.builtin] Log level configured to GLOBAL
2025-03-12 10:34:15.273 INFO (MainThread) [music_assistant] Loaded music provider Music Assistant
2025-03-12 10:34:15.282 DEBUG (MainThread) [music_assistant] Loading provider fully_kiosk
2025-03-12 10:34:15.286 DEBUG (MainThread) [music_assistant] Loading provider radiobrowser
2025-03-12 10:34:15.350 DEBUG (MainThread) [music_assistant.fully_kiosk] Log level configured to GLOBAL
2025-03-12 10:34:15.368 DEBUG (MainThread) [music_assistant.webserver] Handling command player_queues/all
2025-03-12 10:34:15.373 DEBUG (MainThread) [music_assistant.radiobrowser] Log level configured to GLOBAL
2025-03-12 10:34:15.417 DEBUG (MainThread) [music_assistant.webserver] Handling command players/all
2025-03-12 10:34:15.503 DEBUG (MainThread) [music_assistant.webserver] Handling command config/players
2025-03-12 10:34:15.710 DEBUG (MainThread) [music_assistant.webserver] Handling command players/all
2025-03-12 10:34:15.724 DEBUG (MainThread) [music_assistant.webserver] Handling command music/artists/count
2025-03-12 10:34:15.769 DEBUG (MainThread) [music_assistant.webserver] Handling command player_queues/all
2025-03-12 10:34:15.787 DEBUG (MainThread) [music_assistant.webserver] Handling command music/albums/count
2025-03-12 10:34:15.816 DEBUG (MainThread) [music_assistant.webserver] Handling command players/all
2025-03-12 10:34:15.825 DEBUG (MainThread) [music_assistant.webserver] Handling command music/artists/count
2025-03-12 10:34:15.828 DEBUG (MainThread) [music_assistant.webserver] Handling command providers/manifests
2025-03-12 10:34:15.848 DEBUG (MainThread) [music_assistant.webserver] Handling command music/playlists/count
2025-03-12 10:34:15.854 INFO (MainThread) [music_assistant] Loaded music provider RadioBrowser
2025-03-12 10:34:15.877 DEBUG (MainThread) [music_assistant.webserver] Handling command player_queues/all
2025-03-12 10:34:15.950 DEBUG (MainThread) [music_assistant.webserver] Handling command music/albums/count
2025-03-12 10:34:15.952 DEBUG (MainThread) [music_assistant.webserver] Handling command providers/manifests
2025-03-12 10:34:16.169 INFO (MainThread) [music_assistant] Loaded player provider Fully Kiosk Browser
2025-03-12 10:34:16.181 INFO (MainThread) [music_assistant.players] Player registered: 6aed291b-32dcb8d0/Fire Tablet
2025-03-12 10:34:16.463 DEBUG (MainThread) [music_assistant.webserver] Handling command providers
2025-03-12 10:34:16.466 DEBUG (MainThread) [music_assistant.webserver] Handling command music/radios/count
2025-03-12 10:34:16.628 DEBUG (MainThread) [music_assistant.webserver] Handling command music/synctasks
2025-03-12 10:34:16.635 DEBUG (MainThread) [music_assistant.webserver] Handling command music/tracks/count
2025-03-12 10:34:16.787 DEBUG (MainThread) [music_assistant.webserver] Handling command providers
2025-03-12 10:34:16.791 DEBUG (MainThread) [music_assistant.webserver] Handling command music/playlists/count
2025-03-12 10:34:16.857 DEBUG (MainThread) [music_assistant.webserver] Handling command music/synctasks
2025-03-12 10:34:16.863 DEBUG (MainThread) [music_assistant.webserver] Handling command music/radios/count
2025-03-12 10:34:16.877 DEBUG (MainThread) [music_assistant.webserver] Handling command config/core
2025-03-12 10:34:16.952 DEBUG (MainThread) [music_assistant.webserver] Handling command music/tracks/count
2025-03-12 10:34:16.957 DEBUG (MainThread) [music_assistant.webserver] Handling command music/artists/count
2025-03-12 10:34:17.041 DEBUG (MainThread) [music_assistant.webserver] Handling command music/albums/count
2025-03-12 10:34:17.103 DEBUG (MainThread) [music_assistant.webserver] Handling command config/core
2025-03-12 10:34:17.129 DEBUG (MainThread) [music_assistant.webserver] Handling command music/tracks/count
2025-03-12 10:34:17.181 DEBUG (MainThread) [music_assistant.webserver] Handling command music/artists/count
2025-03-12 10:34:17.201 DEBUG (MainThread) [music_assistant.webserver] Handling command music/playlists/count
2025-03-12 10:34:17.271 DEBUG (MainThread) [music_assistant.webserver] Handling command music/radios/count
2025-03-12 10:34:17.280 DEBUG (MainThread) [music_assistant.webserver] Handling command music/albums/count
2025-03-12 10:34:17.355 DEBUG (MainThread) [music_assistant.webserver] Handling command music/tracks/count
2025-03-12 10:34:17.450 DEBUG (MainThread) [music_assistant.webserver] Handling command music/playlists/count
2025-03-12 10:34:17.520 DEBUG (MainThread) [music_assistant.webserver] Handling command music/radios/count
2025-03-12 10:34:21.198 DEBUG (MainThread) [music_assistant.controllers.config] Saved data to persistent storage
2025-03-12 10:34:31.120 DEBUG (MainThread) [music_assistant.webserver] Handling command players/cmd/play_pause
2025-03-12 10:34:31.128 DEBUG (MainThread) [music_assistant.players] Handling command cmd_play for player Fire Tablet
2025-03-12 10:34:31.143 DEBUG (MainThread) [music_assistant.audio] Getting streamdetails for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff
2025-03-12 10:34:33.199 DEBUG (MainThread) [music_assistant.audio] retrieved streamdetails for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff in 2055 milliseconds
2025-03-12 10:34:33.202 DEBUG (MainThread) [music_assistant.players] Handling command play_media for player Fire Tablet
2025-03-12 10:34:33.303 DEBUG (MainThread) [music_assistant.streams] Start serving audio stream for QueueItem KCRW 88.9 FM - Live (radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff) to Fire Tablet
2025-03-12 10:34:33.304 DEBUG (MainThread) [music_assistant.player_queues] PlayerQueue Fire Tablet loaded item 7026f06b9d40487ab4835f12c03988e2 in buffer
2025-03-12 10:34:33.308 DEBUG (MainThread) [music_assistant.audio] Generated ffmpeg params for player 6aed291b-32dcb8d0: ['alimiter=limit=-2dB:level=false:asc=true']
2025-03-12 10:34:33.347 DEBUG (MainThread) [ffmpeg.29] Start reading audio data from source...
2025-03-12 10:34:33.366 DEBUG (MainThread) [music_assistant.audio.media_stream] Started media stream for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff - using streamtype: icy - volume normalization: dynamic - pcm format: f32le - ffmpeg PID: 30
2025-03-12 10:34:33.368 DEBUG (MainThread) [ffmpeg.30] Start reading audio data from source...
2025-03-12 10:34:33.368 DEBUG (MainThread) [music_assistant.audio] Start streaming radio with ICY metadata from url https://streams.kcrw.com/kcrw_mp3?aw_0_1st.playerid=radio-browser.info
2025-03-12 10:34:37.485 WARNING (MainThread) [asyncio] Executing <Handle _UnixReadPipeTransport._read_ready() created at /usr/local/lib/python3.12/asyncio/selector_events.py:280> took 0.121 seconds
2025-03-12 10:43:14.489 DEBUG (MainThread) [music_assistant.streams] Start serving audio stream for QueueItem KCRW 88.9 FM - Live (radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff) to Fire Tablet
2025-03-12 10:43:14.489 DEBUG (MainThread) [music_assistant.player_queues] PlayerQueue Fire Tablet loaded item 7026f06b9d40487ab4835f12c03988e2 in buffer
2025-03-12 10:43:14.496 DEBUG (MainThread) [music_assistant.audio] Generated ffmpeg params for player 6aed291b-32dcb8d0: ['alimiter=limit=-2dB:level=false:asc=true']
2025-03-12 10:43:14.538 DEBUG (MainThread) [ffmpeg.49] Start reading audio data from source...
2025-03-12 10:43:14.559 DEBUG (MainThread) [music_assistant.audio.media_stream] Started media stream for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff - using streamtype: icy - volume normalization: dynamic - pcm format: f32le - ffmpeg PID: 50
2025-03-12 10:43:14.562 DEBUG (MainThread) [ffmpeg.50] Start reading audio data from source...
2025-03-12 10:43:14.563 DEBUG (MainThread) [music_assistant.audio] Start streaming radio with ICY metadata from url https://streams.kcrw.com/kcrw_mp3?aw_0_1st.playerid=radio-browser.info
2025-03-12 10:43:14.627 DEBUG (MainThread) [music_assistant.streams] Start serving audio stream for QueueItem KCRW 88.9 FM - Live (radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff) to Fire Tablet
2025-03-12 10:43:14.629 DEBUG (MainThread) [music_assistant.player_queues] PlayerQueue Fire Tablet loaded item 7026f06b9d40487ab4835f12c03988e2 in buffer
2025-03-12 10:43:14.640 DEBUG (MainThread) [music_assistant.audio] Generated ffmpeg params for player 6aed291b-32dcb8d0: ['alimiter=limit=-2dB:level=false:asc=true']
2025-03-12 10:43:14.782 DEBUG (MainThread) [ffmpeg.51] Start reading audio data from source...
2025-03-12 10:43:14.847 DEBUG (MainThread) [aiohttp.server] Ignored premature client disconnection 2
2025-03-12 10:43:14.847 DEBUG (MainThread) [aiohttp.server] Ignored premature client disconnection.
2025-03-12 10:43:14.859 DEBUG (MainThread) [music_assistant.audio.media_stream] Started media stream for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff - using streamtype: icy - volume normalization: dynamic - pcm format: f32le - ffmpeg PID: 52
2025-03-12 10:43:14.863 DEBUG (MainThread) [ffmpeg.52] Start reading audio data from source...
2025-03-12 10:43:14.864 DEBUG (MainThread) [music_assistant.audio] Start streaming radio with ICY metadata from url https://streams.kcrw.com/kcrw_mp3?aw_0_1st.playerid=radio-browser.info
2025-03-12 10:43:15.279 DEBUG (MainThread) [music_assistant.audio.media_stream] stream cancelled (with code 255) for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff - seconds streamed: 524.0
2025-03-12 10:43:18.736 DEBUG (MainThread) [aiohttp.server] Ignored premature client disconnection 2
2025-03-12 10:43:18.736 DEBUG (MainThread) [aiohttp.server] Ignored premature client disconnection.
2025-03-12 10:43:19.102 DEBUG (MainThread) [aiohttp.server] Ignored premature client disconnection 2
2025-03-12 10:43:19.103 DEBUG (MainThread) [aiohttp.server] Ignored premature client disconnection.
2025-03-12 10:43:21.116 DEBUG (MainThread) [music_assistant.audio.media_stream] stream cancelled (with code 255) for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff - seconds streamed: 2.0
2025-03-12 10:43:21.281 DEBUG (MainThread) [music_assistant.audio.media_stream] stream cancelled (with code 255) for radiobrowser://radio/d675cbad-79cc-44c1-9fa7-38e8bad74aff - seconds streamed: 2.0
i did like this as I have not run a beta before:
2.5.0b12 > downloaded / installed - set for start on boot and started - opened added fire and radio browser
released version > turned off released version and turned off start on boot
restarted HA
turned on error logs and restarted … ooops
opened, played stream … waited for failure and got the log thisis the second one… i tried another stream as well same thing.
Edit: Sorry I was half responding to something else!
So it does look like a device problem or insufficent bandwidth
Check the device settings and make sure MP3 is selected. Also if the sample rates look like the image then try removing the 44.1 option. Make sure you save then try again.
Also please confirm again this problem is only radio streams or do you see it with other media as well.
those were the settings I had default in the above log as I changed nothing else
it seems to be on radio streams. eg, Spotify playlists seem to work fine.
my guess (I am no expert) is that streams maybe only send buckets of data (?)… and when the buckets are empty the music assistant or whatever needs to say, here I am send a new bucket, it gets one, etc… it seems it may be this handshaking that fails somewhere whereas maybe the playlists are already loaded so no handshaking needed? (or?) with that said I have tried queuing up the same radio a few times but that did not work. The work around automation works simply by getting triggered when the player has stopped and just restarts it - what is strange and I guess there is some handling for this already but it seems music assistant should do that if no one has hit stop.
At this point we don’t know why the stream is stopping. Possibly it’s a Fully Kiosk bug. If you get any more useful logs then let us know.
Edit: in fact just restart MA do nothing but start the radio station, wait for it to stop, wait two more minutes then attach the logs here.
