Music assistant is not available
Hello everyone! When I try to run the music assistant, it stops and shows an error. Is there any way to fix this?
2025-03-17 20:49:49.236 INFO (MainThread) [music_assistant] Starting Music Assistant Server (aa961274188a46808ac52032dade466a) version 2.4.4 - HA add-on: True - Safe mode: False
2025-03-17 20:49:49.468 INFO (MainThread) [music_assistant.cache] Initializing cache controller...
2025-03-17 20:50:03.413 ERROR (MainThread) [music_assistant] Error doing task: Task exception was never retrieved
  File "/app/venv/lib/python3.12/site-packages/aiorun/__init__.py", line 223, in new_coro
    await coro
  File "/app/venv/lib/python3.12/site-packages/music_assistant/__main__.py", line 214, in start_mass
    await mass.start()
  File "/app/venv/lib/python3.12/site-packages/music_assistant/mass.py", line 170, in start
    await self.streams.setup(await self.config.get_core_config("streams"))
  File "/app/venv/lib/python3.12/site-packages/music_assistant/controllers/streams.py", line 220, in setup
    await check_ffmpeg_version()
  File "/app/venv/lib/python3.12/site-packages/music_assistant/helpers/ffmpeg.py", line 405, in check_ffmpeg_version
    raise AudioError(err_msg)
music_assistant_models.errors.AudioError: Error determining FFmpeg version on your system. - Your CPU may be too old to run this version of FFmpeg. - Additional info: -4
2025-03-17 20:50:03.624 INFO (MainThread) [aiorun] Entering shutdown phase.
2025-03-17 20:50:03.624 INFO (MainThread) [aiorun] Executing provided shutdown_callback.
2025-03-17 20:50:03.624 INFO (MainThread) [root] shutdown requested!
2025-03-17 20:50:03.625 INFO (MainThread) [music_assistant] Stop called, cleaning up...
2025-03-17 20:50:04.013 INFO (MainThread) [aiorun] Waiting for executor shutdown.
2025-03-17 20:50:04.056 INFO (MainThread) [aiorun] Shutting down async generators
2025-03-17 20:50:04.058 INFO (MainThread) [aiorun] Closing the loop.
2025-03-17 20:50:04.061 INFO (MainThread) [aiorun] Leaving. Bye!
Hello acamaz-ch,
You might want to ask here…
Music assistant
The people that are watching that thread are all either interested. users of, or authors of Music Assistant.
They are likely your best resource.
Also there is a Discord: Music Assistant
