Hi all,
I’m new to Home Assistant.
I set up Music Assistant integration. I successfully shared the music folder from my Windows 10 PC to the HA. I configured the Denon receiver as player via DLNA.
The issue I have is when music is playing in HA via DLNA to my Denon receiver, I don’t see the artwork/album cover and artist/track name on TV that is connected to the receiver. I have a NOW PLAYING screen with the default Music Assistant black screen with the MA logo instead of the artist name/track name and artwork of the currently playing music
I’m running HAOS on a mini PC. It is up-to-date:
Core 2025.3.3
Supervisor 2025.03.3
Operating System 14.2
Frontend 20250306.0
I have a Denon X1400H Receiver and Samsung smart TV. I also have a Win 10 PC.
When music is playing I am able to see the (currently playing) artwork (album cover) in the dashboard - both with Maxi Media Player card (see screenshot) and also with the regular Media Player card.
I also see the artwork in the currently playing playlist in Music Assistant.
Is it possible to configure DLNA/Music Assistant/Denon receiver send artwork to the TV when music is playing? If so, how?
When you’re playing dlna on that player. Do any of the other media player entities that are the same device from another lens have the album art you’re looking for?
I’m not sure what you mean by “from another lens” but I have both Denon Heos integration and Denon AVR Network Receivers integration. Maybe that’s the problem?
So, your setup similarly to me - (I have Denon gear, I suspected this was the case, but I don’t use its DLNA player a lot so I didn’t know what you were seeing…)
Remember your front end does NOT have to be what your scripts and things ACTUALLY use. What I did was set up a Universal media player: Universal media player - Home Assistant that represents what’s actually happening in my stack.
then setup something like this (this is an early version of my living room universal… it’s WAY complicated now - this should get you started.
#Custom Media Player for Living Room
media_player:
- platform: universal
name: Living Room Denon AVR
unique_id: UUID---
device_class: receiver
children:
- media_player.denon_avr_s940h # Replace with your Denon AVR entity ID
- media_player.denon_avr_s940h_2 # Replace with your HEOS entity ID
- media_player.living_room_tv # Replace with your TV entity ID
- media_player.living_room_voice_assistant_media_player # Replace with your Voice Assistant entity ID
- media_player.spotify # Replace with your Spotify entity ID
state_template: >
{% if is_state_attr('media_player.denon_avr_s940h', 'source', 'HEOS Music') %}
{{ states('media_player.denon_avr_s940h_2') }}
{% elif is_state_attr('media_player.denon_avr_s940h', 'source', 'TV Audio') %}
{% if is_state_attr('media_player.living_room_tv', 'source', 'Spotify') %}
{{ states('media_player.spotify') }}
{% else %}
{{ states('media_player.living_room_tv') }}
{% endif %}
{% elif is_state_attr('media_player.denon_avr_s940h', 'source', 'CBL/SAT') %}
{{ states('media_player.living_room_voice_assistant_media_player') }}
{% elif is_state_attr('media_player.denon_avr_s940h', 'source', 'Friday') %}
{% else %}
{{ states('media_player.denon_avr_s940h') }}
{% endif %}
active_child_template: >
{% else %}
{% endif %}
{% else %}
{% endif %}
commands:
turn_on:
service: media_player.turn_on
entity_id: media_player.denon_avr_s940h
turn_off:
service: media_player.turn_off
volume_up:
service: media_player.volume_up
volume_down:
service: media_player.volume_down
volume_mute:
service: media_player.volume_mute
is_volume_muted: "{{ not state_attr('media_player.denon_avr_s940h','is_volume_muted') }}"
select_source:
service: media_player.select_source
source: "{{ source }}"
select_sound_mode:
service: media_player.select_sound_mode
sound_mode: "{{ sound_mode }}"
attributes:
sound_mode: media_player.denon_avr_s940h|sound_mode
sound_mode_list: media_player.denon_avr_s940h|sound_mode_list
source: media_player.denon_avr_s940h|source
source_list: media_player.denon_avr_s940h|source_list
volume_level: media_player.denon_avr_s940h|volume_level
is_volume_muted: media_player.denon_avr_s940h|is_volume_muted
Functionally I make scripts and whatever work with what they’re going to, but THIS is what I Actually show on the front end… This way if my spouse walks up to it and hits a button it works no matter what. So if I need the album art - I pull it from the entity/attribute that has and stuff it into the attribute in this universal. The version posted above doesn’t do that for the art, but each of those attributes should be able to be templated so it can ‘figure out’ what’s what based on state and show one single view of what’s going on. I’ve found it’s good to define one of these anytime you have a bunch of gear people in your home consider ‘one unit’ but in your case you’re just grabbing the data from another angle or ‘lens’
And none of those attributes override the artwork.
You’ll need to look at one of the players (the x400) while it’s running (in dev tools) and look at it’s attributes (check out a Spotify player they’re wild) one of them will be the art.
You can then assign the other value to the dame attribute in your universal.
You can make it switch artwork if you change source by using conditionals etc.
Think through. Ok im in this mode what is going on. This one has this. That one has that. And assemble the attributes make sure they display.
When the attributes are populated the player takes on those attributes and out pops the result - in this case artwork.
