I hope this message finds you well. I am reaching out to ask a question about the Music Assistant program. We have been using it for some time now, and we absolutely love it—thank you for creating such a fantastic tool!
I do have one issue that, while not critical, can be a bit of a hassle. When playing a local radio station using the Radio Browser, the stream stops after two hours. There are no crashes or errors; it simply stops playing. I can restart it immediately, and it will play for another two hours, but this interruption is inconvenient, especially since we like to leave it on overnight.
I suspect there might be a two-hour timer somewhere in the settings that I am not aware of. Below is the YAML configuration I use to call the radio station, and I don’t see any timer settings:
Code
alias: Play Froggy On the Basement Voice
description: Play Froggy In The Basement
triggers:
- trigger: conversation
command:
- play froggy basement
conditions: []
actions:
- action: media_player.play_media
entity_id: media_player.voice_bedroom_media_player
media_content_id: library://radio/1
media_content_type: music
metadata:
title: Froggy 94.9
thumbnail: http://cdn-radiotime-logos.tunein.com/s296107q.png
media_class: music
children_media_class: null
navigateIds:
- media_content_type: music_assistant
media_content_id: radio
mode: single
Any assistance you could provide would be greatly appreciated. As I mentioned, this is not a deal breaker for us; we love the setup and will continue using it. However, it would be wonderful if we could avoid having to restart the stream.
I dont think MA have such a timer, but I know sone radio stations do on their streams.
Streams eats data and data creates traffic and traffic cost money, so the radio stations wants active listeners.
Have you checked the logs @ ha settings > addons > music assistant > logs ?
I found on my home assistant blue, that I was running out of RAM and it would get killed.
If you have a provider configured that has a large library (ie plex or whatever), or possibly many smaller providers, that it can take larger amounts of ram.
thanks for the help i think it is the redio station that is stopping the stream. thought it was some kind of a timer as it was always 2hrs
knew it will not my system:
ASRock Z390 PRO4 Intel LGA1151 DDR4 ATX Motherboard
RAM 64GB DDR4, i7-9700k 8 core 3.6GHz, [ Samsung 990 PRO SSD NVMe M.2 PCIe Gen4, M.2 2280 Internal Solid State Hard Drive, Seq. Read Speeds Up to 7,450 MB
i know over kill so I should never have any problem … i have plans to do a lot with the system and i never wanted it to slow down that why i knew it was not here but on something that i could not control
andwhy that a lot got some ideas … i will see if i can keep it running
well I would try something different than the radio station to see if it last longer, it sounds quite plausible that a free radio stream could be cut off remotely after certain time.
You would have to make an automation, but you would then need something that can be used to detect the state of a stopped or idle connection.
See if you can find that way to detect it.
Alternatively you can add a timer that starts when your station is playing and then when teaching 1:59 stops and starts the music automatically, but you need to know if it is enough to just restart the same stream or you need to start a new stream from the start link.
