so i made an automation for when you toggle home (none) to away (away) for the thermostate… it used to work in previous HA os but i noticed its not working…
i needed to build a work around with the generic thermostate as its missing features for away and such…
so i have 2 file reads for Away (away) and Home (none)
now in my automation its supposed to read the toggle and then choose whatever setting its set to away or none… well now it crashes HA i added extra action to force the Button to away or none as for whatever reason when you Press Away it seems to run but it wont set the Switch to Away it keeps it on None like your at home… and doesnt switch … turn off the automation and it toggles fine… so whatever wrong in my automation does toggle the switch anymore
so the 2nd one used to work but it doesnt it just crashes
if i set the trigger for preset away and just run the away it will set the temperature but it wont toggle the switch it will stay on Home(none) so its not letthing the switch toggle… but it used to work
Can you elaborate on that more?
There’s a range there from it corrupts my database all the way to it drops out and does nothing.
Looking at a trace will help you diagnose what is stopping it.
Related, is none actually a state of this attribute ever? I mean you are triggering when that attribute changes, and none is a bit unusual as an actual state…
so what happens is when i set to 4gigs of ram it ran out of memory … as i run it in a VM
i bumped it to 8gigs ram
so when you press the Away button it doesnt toggle… and HA crashes instantly as the connection says connection retrying or so so i loose connection to the HA but the console i still see working but commands dont wanna work right…
i trigger both none and away… so when its away it forces the away temperature as the target temp… when you set it to none then it sets the target temp to home
i do this because the generic thermostat has a few glitchs in it so i made a work around for it
so i write to a file and use the notification to export the Away and None (Home) temperatures
then i use the FILE intergration to read the value Home (none) and Away (away) values and when you reboot HA whatever mode your in it also sets the temp from the file
but the toggling doesnt work now when it used it… and its like crapping out
ya the code server i let it run all the time. as i just let everything run on its own i only noticed issue cuz oif the automation not working when i couldnt toggle and then i saw the console saying out of memory
Well let me know if I understand correctly your automation:
each time there is a change in the preset_mode of the climate entity, the automation triggers.
then you test if you are in “away” or “none” preset_mode to set the temperature in the corresponding mode…
Correct sofar ?
But what I do not understand is why you are forcing the preset_mode to be “away” or “none” in the code while the condition for the code to run is that the preset_mode is already in “away” or “none” state…
It seems also that you have more automations associated with this one… Maybe good to share the full code… The problem is maybe between two automations written to achieve what you are looking for…
For me, it seems that something is crashing the supervisor…
each time i change from the Preset Away to None it then reads the sensor value from away_temperature_house and sets the target_temp to that value… when you choose None (Home) then it takes the value from sensor home_temperature_house
but when you press the button away… it instantly crashes … it was working in the previous update of HA as you could go back and forth away and the away button toggle… but right nwo it defaults to none(Home) and u cant switch to away. and then it instantly crashes HA or locks it up only the console works somewhat
so for the Toggling the automation is below i used to have it in 2 automations but made it into 1…
and ir your asking why i tellin the automation to force the button to away or none
is because when you click on away… it would do nothing or just pop the value from the file… but it would still only state in none mode… it wouldnt flip to away mode… so i tried forcing it… but right now it just keeps crashing
the only reason i noticed a problem is my furnace was supposed to be set to away mode for a week and i had updated HA forwhatever happened when HA rebooted or so it set itself to Home(none) and i tried to set it to away and thats where i find it crashing or running out of ram when i had it at 4 gig of ram… but it was working a update or 2 ago which update like core os supervisor i not sure but was working a week and half ago but in mean time i did update tthem
upgraded just now to core 2025.2.2 and i re tested… it hasnt crashed
but when you press the not home button it doesnt put the not home temperature in… it puts in the home temperature and stays on none(home) so it wont toggle to away
as you can see in my video it doesnt set to the away sensor value cuz it wont toggle over to away… it will toggle heat and idle on the preset away and it only puts in the home sensor temperature value not the away… it used to work now it wont and i had them in 2 seperate automations to toggle from none to away and away to none
here is my one drive link to the video https://1drv.ms/f/c/2759db01e8e27b46/EqrInQquK59AlRz6mJ-MnGQB12iMNBwd7JYZQM1-wOECSA?e=zoviYa
as you can see why i had the force the toggle over to away or to none cuz its not flipping on its own anymore when the automation is running if you disable it… then the toggle switch works but then loads from the preset away and not from the file
