My first automation didn't run correctly
Hi guys,
I’m moving over from OpenHab to HASS.IO.
And to be honest, I wish I would have done this months ago…
However I am having some trouble running my first automation.
According to the logs it DID run, but nothing happened.
# Reset kWh teller water boiler
alias: Reset Meter Boiler
  - at: '00:01'
    platform: time
  - service: script.reset_energy_meters
I use this to reset my Fibaro Wall Plug energy meter. (Z-wave)
What am I doing wrong here?
Edit: My scripts.yaml file is empty. Is “reset_energy_meters” predefined?
It’s a service not a script. https://www.home-assistant.io/components/utility_meter/#services
  - service: utiltiy_meter.reset
    entity_id: utility_meter.your_utility_meter_entity_id_here
Hello Zweetkonijn,
and welcome to the forum. I think the transition from openHAB will not be easy for you, (I could not handle openHAB at all!) But I think the people here in the forum will be happy to support you and give you tips
:+1:
greetings
For anyone in the future who is having trouble configuring their Fibaro wall plug.
This code did the trick, now it resets every time at 0:01 am.
  - alias: Reset Meter Boiler
      - at: '00:01'
        platform: time
        - service: zwave.reset_node_meters
          data: {"node_id":2}
