Hi. I created my first fully customizable card to show animated energy flows.
The card looks similar to the one you can use in homey.
There will be a couple of SVG backgrounds soon!
Features
- Animated SVG flow lines per energy source (positive & negative direction)
- Up to 8 configurable energy value pills in a 3×3 grid
- Only SVG flow also possible
- Up to 10 daily entity values with optional secondary entity
- Per-entity column width: half width (1-col) or full tile width (2-col)
- Configurable grid breakpoint that controls the 2-column → 1-column layout switch
- Day/night SVG backgrounds with auto-switching via sun entity
- Fully configurable via the visual editor (no YAML required)
- Touch-compatible drag & drop sorting in the editor
- YAML editor fallback per entry
Configuration
Add the card to your dashboard via the visual editor, or paste the YAML manually.
Minimal example
type: custom:energy-flow-card
svg_day: /local/energyflow/isometric.svg
svg_night: /local/energyflow/isometric_night.svg
mode: day
energy_values: []
daily_entities: []
Full example
minmax_min_width: 175px
entity_grid: sensor.house_power_curr
entity_solar: sensor.curent_solar_production
entity_battery: sensor.curent_battery_production
entity_house: sensor.energy_consumption
mode: day
entity_sun: sun.sun
energy_values:
- entity: sensor.shellyplus1pm_a8032ab748e0_power
position: top-left
label: Batterie
color_positive: "#97EA63"
path_positive: >-
M163.503 1071.5L163.503 646.494C163.503 646.494 162 631.489 170.499
618.991C178.999 606.493 189.503 603.494 189.503 603.494L259.064 569
color_negative: ""
path_negative: ""
- entity: sensor.combined_solar_current_production
position: top-right
label: Solar
color_positive: "#FFD724"
path_positive: >-
M328.409 425.054L328.425 411.899C328.425 411.899 326.887 396.319 335.692
383.331C344.497 370.342 355.365 367.217 355.365 367.217L643.064 224.783
color_negative: ""
path_negative: ""
delay_positive: "-0.8s"
- entity: sensor.stromzaehler02_haus_power_curr
position: bottom-left
label: Grid
color_positive: "#64B7F6"
path_positive: >-
M163.822 1193.5V1331.13C163.822 1331.13 165.088 1346.15 156.392
1358.52C147.695 1370.88 136.564 1374 136.564 1374C105.564 1385.5 112.064
1407 112.064 1407C112.064 1407 110.564 1413 126.564 1426.5C142.564 1440
177.441 1455.53 177.441 1455.53L834.576 1788.22L318.041 2051.41
color_negative: "#D650DC"
path_negative: >-
M318.041 2051.41L834.576 1788.22L177.441 1455.53C177.441 1455.53 142.564
1440 126.564 1426.5C110.564 1413 112.064 1407 112.064 1407C112.064 1407
105.564 1385.5 136.564 1374C136.564 1374 147.695 1370.88 156.392
1358.52C165.088 1346.15 163.822 1331.13 163.822 1331.13V1193.5
delay_positive: "0"
delay_negative: 1.7s
- entity: sensor.energy_consumption_new
position: bottom-right
label: Verbrauch
path_positive: >-
M413.96 1219.65C413.96 1219.65 402.284 1230.08 386.602 1230.62C370.92
1231.17 361.987 1224.24 361.987 1224.24L206.065 1149.5
color_negative: ""
path_negative: ""
delay_positive: 0.4s
daily_entities:
- entity: sensor.daily_grid_consumption
label: Grid
icon: mdi:transmission-tower
color: "#64B7F6"
secondary_entity: sensor.daily_grid_feed
secondary_icon: mdi:arrow-top-right
secondary_no_unit: true
- entity: sensor.daily_solar_production
label: Solar
icon: mdi:solar-power
color: "#FFD724"
- entity: sensor.daily_heat_consumption
label: Heizung
icon: mdi:fire
color: "#FF6B35"
- entity: sensor.daily_battery_consumption
label: Battery
icon: ios:battery-50percent
color: "#97EA63"
secondary_entity: sensor.awtrix_5686f0_battery
col_span: 2-col
Configuration options
Top level
| Option | Type | Default | Description |
svg_day |
string | Path to the SVG background for daytime | |
svg_night |
string | Path to the SVG background for nighttime | |
mode |
auto / day / night |
day |
Display mode. auto switches based on entity_sun |
entity_sun |
entity | Any entity whose state is below_horizon for night detection |
energy_values |
list | [] |
Up to 8 energy pills including energy flow animations (see below) |
daily_entities |
list | [] |
Daily total values shown below the SVG (see below) |
general settings |
additional hidden settings | [] |
Basic settings (see below) |
energy_values entry
| Option | Type | Description |
entity |
entity | Sensor entity to read the value from |
position |
string | Pill position: top-left, top-center, top-right, middle-left, middle-right, bottom-left, bottom-center, bottom-right You can select each postion only once. So choose wisely. |
label |
string | Label shown above the value in the pill |
hide_value |
boolean | false |
color_positive |
string | Hex color for positive flow animation (e.g. #64B7F6) |
path_positive |
string | SVG path d attribute for positive flow direction |
delay_positive |
string | CSS animation delay for positive flow (e.g. 0s, -0.8s) |
color_negative |
string | Hex color for negative flow (leave empty to reuse positive color) |
path_negative |
string | SVG path d attribute for negative flow direction |
delay_negative |
string | CSS animation delay for negative flow |
daily_entities entry
entity |
entity | Sensor entity for the daily value |
label |
string | Display label (leave empty to use friendly name) |
icon |
string | Icon (e.g. mdi:solar-power). If omitted, the entity’s own icon is used automatically |
color |
string | Icon color (hex) |
secondary_entity |
entity | Optional second value shown small beside the main value |
secondary_icon |
string | Icon for the secondary value |
secondary_no_unit |
boolean | Hide the unit of the secondary value |
col_span |
1-col / 2-col |
1-col |
general settings
minmax_min_width |
string | 175px |
Minimum tile width before the grid collapses from 2 columns to 1 (e.g. 175px, 200px, 50%) |
flow_height |
string | 265px |
Height of the SVG flow area, this changes also the height of the card (e.g. 265px, 300px) |
svg_height |
string | Fixed height for the SVG, background image and energy flows. When set, both are centered vertically within the flow area. Leave empty to fill the full flow height (e.g. 220px) |
gradient_day |
string | linear-gradient(to bottom,#2A75F6 0%,#FFFFFF 67%,#D5D5D5 100%) |
CSS background gradient for day mode |
gradient_night |
string | linear-gradient(to bottom,#0A1929 0%,#1A2332 67%,#2C3440 100%) |
CSS background gradient for night mode |
viewbox_width |
string | 1676 |
SVG viewBox width — change when using a custom SVG with different dimensions. |
viewbox_height |
string | 2058 |
SVG viewBox height — change when using a custom SVG with different dimensions |
SVG paths
The flow animation follows SVG path elements. To get the correct paths for your own SVG:
- Draw your isomisometric SVT (e.g. affinity studio, Figma)
- Trace the desired flow line as a path
- Copy the
dattribute value - Paste it into
path_positive/path_negativein the card config (a negative path is the positive version but from last to first point)
The default SVG viewBox is 0 0 1676 2058. If your SVG has different dimensions, set viewbox_width and viewbox_height in General Settings accordingly.
