None of them are working, and they all use Big Timer, so I’m thinking I might have big timer misconfigured?
I’ve read the documentation, but it appears to be configured correctly. I’ll use my simplest automatio, which is supposed to turn on my backyard floodlight for 10 minutes when the slider is open after sunset and before sunrise. Currently, when I open the slider after hours, it says something about manual override, I forgot to take a screenshot of it. I think it might be due to the fact I have the slider send “on” when it’s open, and apparently, that’s an override function? How else could I tell bigtime that the slider is open and if it’s dark, to run on the light?
That light also never turns on, even when Big Timer is talking about the override.
[{"id":"df2a34fc.1b1348","type":"tab","label":"Slider open when dark out","disabled":false,"info":"Turn on the backyard flood light when slider is opened after dusk, and before dawn. "},{"id":"c93a7896.149678","type":"server-state-changed","z":"df2a34fc.1b1348","name":"Slider","server":"26956a45.92d866","version":1,"entityidfilter":"binary_sensor.slider_contact","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":90,"y":220,"wires":[["8f8eb913.1c5378"],["7ba443cc.d9f43c"]]},{"id":"2944f2b8.138d4e","type":"api-call-service","z":"df2a34fc.1b1348","name":"Flood Light On","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.flood","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":402,"y":167,"wires":[[]]},{"id":"90a7e364.38359","type":"api-call-service","z":"df2a34fc.1b1348","name":"Flood Light Off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.flood","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":423,"y":253,"wires":[[]]},{"id":"8f8eb913.1c5378","type":"bigtimer","z":"df2a34fc.1b1348","outtopic":"","outpayload1":"","outpayload2":"","name":"Dark Out?","comment":"","lat":"27.918981","lon":"-81.866833","starttime":5001,"endtime":"5000","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"repeat":true,"atstart":false,"odd":false,"even":false,"x":237,"y":180,"wires":[["2944f2b8.138d4e"],[],[]]},{"id":"7ba443cc.d9f43c","type":"stoptimer","z":"df2a34fc.1b1348","duration":"10","units":"Minute","payloadtype":"num","payloadval":"0","name":"","x":248,"y":260,"wires":[["90a7e364.38359"],[]]},{"id":"26956a45.92d866","type":"server","z":"","name":"Home Assistant"}]
