My planned Home Assistant server for reboot
Hi all. I am running HAOS on a dedicated NUC today. The same instance has been running for about 3 years now and so many things have changed over the years… I want to start from scratch with new namespaces, new structure and just get a very clean start. At the same time I am restarting my entire network with a brand new site setup in my Unifi system.
My strategy is to set up a brand new network + HA instance side by side with the existing one and then migrate over devices and settings one by one from the stuff I want to continue to keep going.
In order to do this the only way is to setup a brand new barebone server for HAOS and get that fresh install on it.
I have chosen this setup and would like to hear your feedback.
Base unit
  • ASUS NUC 14 Essential Barebone – Intel N250
    • 4 cores / 4 threads
    • DDR5 support
    • 1× M.2 NVMe slot
    • 2.5G Realtek LAN
    • Wi-Fi 6E + Bluetooth 5.3
Memory
  • Kingston Fury Impact 16 GB DDR5-4800 (1×16 GB)
Storage
  • WD Black SN7100 1 TB NVMe Gen4 SSD
Radio dongles (Nabu Casa / Home Assistant)
  • Home Assistant Connect ZBT-2
  • Home Assistant Connect ZWA-2
Accessories
  • USB extension cable (1 m) for each dongle → improves signal quality and reduces RF interference (as my HA server sits in a cabinet on a 19" shelf)
The total cost lands on about €600.
What do you guys think?
Your replacing Nuc for another Nuc?
Not sure that has any benefit.
other than that sound good.
Yeah my plan is to migrate over from the current nuc to the new one to not have a disruption to the current HA. Once competed I’ll repurpose the current nuc for another job.
You should use proxmox then as you could setup 2 instances with the same IP address and close one down and open the other whilst working on it and then go back to the original without having to run 2 setups and all the hassle involved in reconnecting stuff to each server.
You can’t just install HomeAssistant on the new hardware, backup the old and restore it to the new?
Put your old one away as a backup hardware option in case the new one goes bad.
Simplez!
My feedback, @nswe I like that setup :wink: looking at something similar. Are you happy with it so far?
I ended up using a HP Elitedesk 800 G5 and installed 32GB DDR4 and 2TB Evo 990 SSD in it…Works great besides some NIC issues that has been intro with the latest Proxmox kernel crashing the network so I will need to fix that next
