My recently bought aqara door sensors are not recognized properly
My recently bought aqara door sensors are not recognized properly.
However pairing reports the new sensor as “ready to use” in the configured devices section the sensor is seen as a ias_zone and the power shows 'unknown". The zigbee device signature lists a different device_type, clusters, model and class then my older agara door sensors. I’m running RPI4, raspbee II, zha with several devices including agara door, waterleakage, motion, temp/humidity sensors and they all work fine. I have debug log available.
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4447, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)”,
“endpoints”: {
“1”: {
“profile_id”: 260,
“device_type”: “0x0402”,
“in_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”,
“0x0500”,
“0xfcc0”
“out_clusters”: [
“0x0003”,
“0x0019”
“manufacturer”: “LUMI”,
“model”: “lumi.magnet.acn001”,
“class”: “zigpy.device.Device”
will be fixed in Add quirk for Aqara E1 contact sensor by dmulcahey · Pull Request #1151 · zigpy/zha-device-handlers · GitHub
