I applied recent z-wave JS UI update to 1.6.0 and now I can no longer access the UI. I attempted ro roll back using restore from backup, and now z-wave JS has an error Retrying setup: Failed to connect: Cannot connect to host xxxxxxxx-zwavejs2mqtt:3000 ssl:default [Connect call failed ('172.30.33.0', 3000)]
This error is in the devices and services page.
If I click configuration I get the following error Failed to connect: Cannot connect to host xxxxxxxx-zwavejs2mqtt:3000 ssl:default [Connect call failed ('172.30.33.0', 3000)]
If I try to go to the zwav JS UI then I get a bad gateway error.
All I did was apply an update? Any help in resolving this is much appreciated.
