Myenergi integration - select charge rate
Is it possible for a select button be added to the myenergi integration to enable users to select the charge rate? It is possible on the physical zappi, so hopefully some clever person is able to add this feature
Hello jason19771977,
This does not appear to be a Home Assistant Core Integration.
You would need to ask the Custom Integration Author(s) to do this.
