Hi All,
I’ve currently set libbi to charge to 100% using lower overnight tariffs. As the seasons change I’d like to use HA to reduce that percentage based on forecast solar generation but I can’t see any sensors in myenergi that show the existing charge level limit setting and allow it to be changed. As anyone come up with a solution for this please?
The sensor you’re looking for is in the Libbi entity and called ‘myenergi libbi-99999999 SoC’. The 99999999 I think is the serial number of your Libbi; mine starts 240*****. I have it working & showing the %age charge in a card so far, I’m looking to work out how to set it in HA. Got rather distracted by importing import and export values from Octopus.
