I tried making a motion/light/door sensor and everything seems to work fine, except the light sensor doesn’t show up in home assistant. The problem seems to be me using V_LEVEL to pass exact lux amount. As I understand it, this should work fine? I can seen in gw log that lux value and “custom_lux” prefix get transferred as expected. Any help would be appreciated as I seem to be lost at this point…
2019-03-07 19:29:57 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 1 child 3
2019-03-07 19:29:57 DEBUG (MainThread) [homeassistant.components.mysensors.helpers] Invalid values: {37: '1'}: sensor platform: node 1 child 3: S_LIGHT_LEVEL requires value_type V_LIGHT_LEVEL @ data[23]
Relevant code:
#define MY_RADIO_RF24
#include <MySensors.h>
#include <SPI.h>
#include <Bounce2.h>
#include <Wire.h>
#include <BH1750.h>
#define CHILD_ID_LIGHT 3 //ID of light sensor
uint16_t lastlux=0; //light sensor
BH1750 LightSensor; //declaration of light sensor
MyMessage msg_light(CHILD_ID_LIGHT, V_LEVEL); //light sensor message
MyMessage msgPrefix(CHILD_ID_LIGHT, V_UNIT_PREFIX); //custom unit for light sensor
void setup()
LightSensor.begin();
send(msgPrefix.set("custom_lux")); //light sensor setup for hassio
send(msg_light.set(lastlux));
request(CHILD_ID_LIGHT, V_LEVEL);
wait(2000, C_SET, V_LEVEL);
void presentation()
sendSketchInfo("Motion/Door/Lux sensor", "1.0"); //info about the sensor
present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
void loop()
uint16_t lux = LightSensor.readLightLevel(); //only send light info if the motion sensor was triggered
if (lux != lastlux) {
send(msg_light.set(lux));
lastlux = lux;
